Old 10-22-2019, 04:55 PM   #1
jack wingard
Default brake adjustment
My left rear brake adjustment wedge will not turn, all others are fine. Any tips?
jack wingard is offline   Reply With Quote
Old 10-22-2019, 07:40 PM   #2
larrys40
Default Re: brake adjustment
Has it been moveable before? Try backing it off rather than tightening . Try some penetrant and then moving it back and forth. If you can get some movement you should feel the detent of the actuating wedge shafts a-2042.
You may have to remove the drum and see what’s going on . You will have to remove the e brake plate to get the rear shoes out and assess for removal and repair.
Typically they will move with lubricant and a big enough brake wrench .
Larry shepard
larrys40 is offline   Reply With Quote
Old 10-22-2019, 09:38 PM   #3
CWPASADENA
CWPASADENA's Avatar
Penetrating oil and patience.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 10-23-2019, 05:16 AM   #4
Gerald1961
Gerald1961's Avatar
release completely the actuation rod. If there is too much tension o the rod, this might also press the plates on the drum and does not allow to release the adjustment.
Gerald1961 is offline   Reply With Quote
Old 10-23-2019, 05:19 AM   #5
jack wingard
Larry shepard
the car is new to me. won't budge either direction
Old 10-23-2019, 05:20 AM   #6
jack wingard
thanks, i'll try thiss
Old 10-23-2019, 05:22 AM   #7
Patrick L.
Patrick L.'s Avatar
penetrating oil, ATF, heat and keep tapping straight in from the end with a hammer while trying to turn it.
Old 10-23-2019, 07:18 AM   #8
History
History's Avatar
What could be the cause of this other than not being turned for a very long time.
History is offline   Reply With Quote
