08-06-2019, 07:52 PM | #1 |
'40 Rod, engine radius 48-6044
What is the best way to remove the square drive flathead screws that hold the rods to the frame ? The square drive is a little larger than 1/4", like maybe 5/16". Is there square drive socket or tool that size ? Thank you Fordbarners.
08-06-2019, 07:57 PM | #2 |
Re: '40 Rod, engine radius 48-6044
I made one out of a piece of 5/16 key stock, welded into an old 3/8 drive socket, believe I had to grind a little on the key stock to make it fit the radius rod bolt
08-06-2019, 09:11 PM | #3 |
