Old 08-05-2019, 04:33 PM   #1
1roger41
Default 37 ford transmission
I would like to know if 1937 Ford 3 speed transmissions are the same for truck (1/2ton ) and cars. I don’t know if this is the right place , but what the , thanks
1roger41 is offline   Reply With Quote
Old 08-05-2019, 04:40 PM   #2
fordscript
fordscript's Avatar
Default Re: 37 ford transmission
Yes, they are all the same.
fordscript is offline   Reply With Quote
Old 08-05-2019, 04:52 PM   #3
1roger41
Thank you for the quick response . My first time writing to Ford Barn , great information here thank you Roger
Old 08-05-2019, 06:20 PM   #4
rotorwrench
rotorwrench's Avatar
There are different gear sets on some of the older commercials. Some were still spur cut gears. Mac VanPelt's transmission book has several pages dedicated to identification for fitting the correct parts together to make a good set of gears. They definitely had the same case and synchronizer but I'm not so sure about the ratios.
Old 08-05-2019, 06:35 PM   #5
alanwoodieman
29 tooth cluster for commercial, 28 tooth for car, 29 is really just a lower first gear
alanwoodieman is online now   Reply With Quote
Old 08-06-2019, 01:39 PM   #6
Hoop
Hoop's Avatar
They are not all the same. In 1937, 2 different engines with different transmissions were produced and available in both car and PU. Definitely different cases and will not interchange.
1roger41 has not told us what he's doing ... would certainly help.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
