Old 08-04-2019, 06:05 PM   #1
FrankWest
FrankWest's Avatar
Default lubricating speedometer
During idling my speedometer hand is bouncing around, and the speedometer is making noise. Are there oil fill locations or does it have to taken apart.
FrankWest is offline   Reply With Quote
Old 08-04-2019, 09:51 PM   #2
Tinker
Tinker's Avatar
Default Re: lubricating speedometer
Start by taking it apart and cleaning it well, flush with acetone or other, inspect ends. Use some graphite spray on the inner part and put it together. A start anyway.
Old 08-04-2019, 10:39 PM   #3
nelsb01
nelsb01's Avatar
First, find out what maybe the cause. Unscrew the cable end from the back of the speedometter housing. If the needle movement stops, its the cable and it needs attention. Carefully remove the cable. Clean it with solvent. I use liquid graphite and lightly coat the cable and reinsert in housing. You will have to probably twist the cable to get it to seat in the gear housing. Add some more liquid graphite into the housing before screwing it back on to the speedometer housing.
If it is not the cable, then Tinker's suggestion will be the next step.
nelsb01 is offline   Reply With Quote
Old 08-04-2019, 11:06 PM   #4
Tinker
Tinker's Avatar
That's a lot of pressure. ha ha. I like to think that I'm just part of the group process. And as easily ignored. I was taking about the cable.
Old 08-04-2019, 11:20 PM   #5
VeryTangled
VeryTangled's Avatar
Just throwing something out there. One other element is the spedo gear at the "turtle" area. Make sure it's lubed and has a decent gasket?
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 08-05-2019, 12:58 PM   #6
FrankWest
FrankWest's Avatar
Perhaps a silly qiestion.... when the transmission is in neutral, with the car parked, is anything turning in the speedometer which is connected to the cable?
Old 08-05-2019, 06:29 PM   #7
1931 flamingo
1931 flamingo's Avatar
In neutral, nothings turning. Speedo only turns when rear wheels are turning.
Paul in CT
Old 08-06-2019, 06:40 AM   #8
FrankWest
FrankWest's Avatar
Paul in CT
seems logical, but why was the dial bouncing around with the engine running in neutral and stationary?
Old 08-06-2019, 06:41 AM   #9
FrankWest
FrankWest's Avatar
what is the turtle?
Old 08-06-2019, 07:05 AM   #10
Terry,OH
Terry,OH's Avatar
Vibration from engine running is the only thing that could cause speedometer needle to bounce if the wheels are not turning. Turtle is the device at the torque tube that the speedometer cable attaches to.
Old 08-06-2019, 08:37 AM   #11
Faro
Faro's Avatar
On similar subject; my speedometer works, but not the odometer. Is there a fix solution?
Faro is offline   Reply With Quote
Old 08-06-2019, 09:51 AM   #12
glennpm
glennpm's Avatar
Hi Faro,
- What model and year is your Ford?
- Are both the trip odometer and the main, non-adjustable odometers not working?
Glenn
Old 10-05-2021, 08:17 PM   #13
Faro
Faro's Avatar
sorry Glenn, lost track of this post. fixed now. TKS for responding
I'm into brake lines now, see new post
Old 10-06-2021, 03:26 PM   #14
glennpm
glennpm's Avatar
Okay and thanks for replying to me.
Glenn
Old 10-06-2021, 03:40 PM   #15
Lawson Cox
Lawson Cox's Avatar
Not sure what year or make of speedometer but usually you have to either pull out on the knob on the back, or push it in, to set the trip odometer. Try it both ways and see if it works.
