08-04-2019, 07:48 AM | #1 |
Axle perch bolts 37-39
Can original type 37 axle perch bolt be purchased?
I’m rebuilding a 37 axle and I am having a hard time getting the perch pin bolt out. Thinking of leaving it in and painting it all together. I will be using original shocks. Last edited by 36coupe; 08-08-2019 at 05:56 PM. |
08-04-2019, 08:46 AM | #2 |
Re: Axle perch bolts 37-39
they can be a SOB to get out. most i've done required a press and some heat. i'm sure you can find used or nos replacements, perhaps new, but if only being removed to paint, i think i would leave it all together
08-04-2019, 09:01 AM | #3 |
Good advice. Unless you need to remove the pin for some reason leave it alone, paint it, and forget it.
08-05-2019, 12:23 AM | #4 |
If you want to remove the perches and want to save them. Remove the axle and arms and put it on a press (use a nut flush on it). Heat them, spray, and use a pipe wrench to turn them before the press. See if they turn a bit. Patience. Not sure anyone makes them and originals get gobbled up by A hotrodders.
Really nothing wrong with just painting them and installing. Only issue I can think if they a hollowed out and need to be sleeved. . Last edited by Tinker; 08-05-2019 at 01:30 AM. |
08-05-2019, 04:29 PM | #5 |
