Old 05-19-2010, 11:06 AM   #1
Byron Warwick
Byron Warwick's Avatar
Default Fuel Pump Filter
Can someone post the NAPA number for the fuel filter that goes in the bowl of the '49-'53 flathead engine. Is this filter enough or is it just a screen?
The picture was my '34 pu in the homecoming parade at MacMaster U. For some reason one of the tires sprung a leak and we did not finish. Right rear looks a bit low. Byron.
Can someone tell me how to post my pictures bigger?
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 05-19-2010, 12:17 PM   #2
ken ct
Default Re: Fuel Pump Filter
Napa #3039,you still need a spring under it and a good fitting cork gasket,screens,cork gasket,spring and filtercenter hole must be hogged out a little as it wont fit over the nub in the pump. Screen goes in first,then the gasket,then the filter,then the spring. Do this with the pump upside down,then slide the bail over the glass bowl and tighten the thumb wheel and your set to go.NAPA will only have the filter. I have the rest. ken ct.
ken ct is offline   Reply With Quote
Old 05-19-2010, 10:15 PM   #3
Byron Warwick
Ken: I Have the cork gasket and the screen. I found the rubber gasket sealed better,and have used it although I have to replace it with a new one each time I remove the bowl. Am I better of to put an inline filter along side the frame, and before the pump?
