01-16-2016, 05:08 PM | #1 |
Question about using 32-34 front axle in model A
My question is when a 32-34 front axle, 32 spindles, 32 perches, on a model A and keeping manual brakes. Which king pin set do you use when rebuilding with new bushings and bearings? A model A 28-31 set or model B 32-34 set? Thanks Ben
01-16-2016, 06:12 PM | #2 |
Re: Question about using 32-34 front axle in model A
Model A
Bob |
01-16-2016, 06:56 PM | #3 |
Thanks Bob
01-16-2016, 11:21 PM | #4 |
Here's a couple of pictures.
Bob |
01-17-2016, 09:41 AM | #5 |
Why have you decided on these 1932 parts? Wayne
01-17-2016, 12:35 PM | #6 |
So I collected a couple of parts to help it get lower and still keep it OE ford parts kinds. I have a reversed eye T spring for the rear, 34 front axle and spindles=1.5" of drop, 32 perches, stock model a wishbone, flatted out A to 32 style front crossmember which should give me another 1" or so. And a reversed eye front main spring as well that I plan on adding or removing leaves to adjust it as needed. |
01-17-2016, 12:38 PM | #7 |
Here is a current picture of the Tudor.
01-17-2016, 12:40 PM | #8 |
And a couple of the parts I have collected so far.
01-17-2016, 02:34 PM | #9 |
Bob is correct, the model A pins, acctuators ect work on the 32 stubs. I think you can use 32 pins but then use all 32 stuff but you can't mix.Here is another picture,though I didn't use 32 perches..
01-17-2016, 04:18 PM | #10 |
Listen to what Bob C says. Using the 32 perch pins and A kingpins and acuators keeps the brake rods and everything in line. Since your going with 32 spindles I assume your using 32 brakes also, if not I suggest you do and a Flathead Ted kit.
01-18-2016, 12:28 PM | #11 |
Use Model A king pins. Old post of mine here that talks about what's needed. http://www.fordbarn.com/forum/showthread.php?t=12576
I've since switched to 40 hydraulic brakes up front. |
Thread Tools | |
Display Modes | |
