Old 08-18-2016, 04:48 PM   #1
firechief5215
firechief5215's Avatar
Default Spray gun for touch up
Does any one have any suggestion's on a small touch up spray gun, I finally got the worm drive rear in our AA' came out very nice , I had the rear painted before install but we scratched it up in a few places and the truck frame also needs a little touch up also. We used a base coat clear coat, I would like to buy some type of touch up spray gun to do this job Thanks Billy I know I will have to a lot of taping
firechief5215 is offline   Reply With Quote
Old 08-18-2016, 05:31 PM   #2
coupe1942
coupe1942's Avatar
Default Re: Spray gun for touch up
Unless you just love using a spray gun, go to Sherwin Williams or Lowe's and pick up a Preval spray system for a nice job and essentially low cost. It is reusable and easy to use on compressed air charge. No compressor necessary.
https://youtu.be/Fpbh3tLyfss
If you like a cheapie gun for what your doing, a Harbor Freight (jam gun) or touch up spray gun is about as cheap as you can get and still do nice work. Ace and even WalMart sell jam guns. You will need a compressor for this gun though. The hvlp guns there are almost as cheap and seem to work fine for our type of work project.
Good luck in your choice.
coupe1942 is offline   Reply With Quote
Old 08-18-2016, 08:38 PM   #3
Tinbasher
Tinbasher's Avatar
Sata makes a great Mini Touch up gun. Not cheap but it works like a full size top coat gun.
(Mini-Jet)
John Poole
Tinbasher is offline   Reply With Quote
Old 08-18-2016, 09:01 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
A cheep Airbrush from Harbor Freight, does an EASY job of touch up, with virtually NO masking. My Pin Striper Friend is a MASTER with one. He filled some black chips for me, a whisp of 3,000 grit sandpaper & polish & they were perfect.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-19-2016, 08:26 AM   #5
captndan
captndan's Avatar
I have a HF HPLV that has only been used once. It's yours for free just pay postage.
captndan is offline   Reply With Quote
Old 08-19-2016, 09:18 AM   #6
C26Pinelake
The Harbor Freight gun will serve your needs very well. Wayne
C26Pinelake is offline   Reply With Quote
Old 08-21-2016, 04:21 PM   #7
Binger
Binger's Avatar
I have Sata Mini jet gun and it is awesome but very expensive. I can get a better gun finish from it than I can my topcoat gun(on small parts).
Binger is offline   Reply With Quote
Old 08-21-2016, 04:58 PM   #8
coupe1942
coupe1942's Avatar
I used to have two Sata hvlp guns and loved them more than any I had ever used at the time. Unfortunately, they have never been cheap to purchase tough and a good Devilbiss just seemed as comfortable as long as you had one that didn't spit when it got low on paint.
I had a couple of shoulder surgeries in the past and I can't hold up the weight of a spray gun without my hand shaking like crazy these days. A good, small hvlp or jam gun is about all I am good for now days. An air brush, too. That Preval unit works well for the small stuff I do at times.
