09-08-2017, 01:38 PM | #1 |
!941 Ford Coupe vent Window
Is it possible to have a glass cut to fill the opening of the vent window and window there by eliminating the vent window?? Sorry that is for the front and passenger door ??THANKS Jerry
09-08-2017, 01:51 PM | #2 |
Re: !941 Ford Coupe vent Window
I'm not sure about '41, but in'46 some models had a rear vent window that did not open. I don't know if the rubber seal is still available for these models. Check with some of the suppliers.
09-08-2017, 02:08 PM | #3 | |
Untitled by philip sauber, on Flickr
41 woodie https://41fordwoodie.weebly.com/ |
09-08-2017, 02:57 PM | #4 |
So if I understand you put a permanent glass in the vent that use to pivot. I was thinking of a glass that would roll up and down and cover the window and vent window area? Thanks Jerry
09-08-2017, 04:16 PM | #5 |
So your wanting to make it like say a 38/39 door window?
09-08-2017, 07:05 PM | #6 |
09-08-2017, 07:28 PM | #7 |
If I'm reading your question correctly you want to remove the vent window and have a one piece glass. A lot of hot rodders do this, so I would ask the question on the HAMB. A couple of companies that come to mind are Specialty Power Window and Electric-Life. I don't know if your stock crank style equipment will be able to handle a larger window and you will have to fabricate a track for the front of the door.
09-08-2017, 08:51 PM | #8 |
OK thanks for the info and I will contact them. Jerry
09-08-2017, 08:59 PM | #9 |
Does any one know the dimensions of the 1938 Ford coupe front door window glass< ?Thanks Jerry
