10-12-2014, 08:22 PM | #1 |
#*&! Fuel Tank Replacement
Would anyone be surprised if a 90 minute job turned into a 5 hour event?
I got a steel tank from Bob Drake and went at it today. The old tank wiggled in and out from the bottom just fine so I expected the same. Didn't happen. No fussing about Bob or his suppliers - everything lined up and it would have been a breeze to drop in from the top. Either my span just wasn't wide enough or the flange may have been 1/4 to 3/8 too wide. Best I could do was to top-mount the filler side and under-mount the passenger side - after cutting off the cage nut. I'd like to get a second bolt on that side....but at least it's in before the weather turns & my JB Weld repairs drop off!
John Haelig Bridgewater, NJ 1939 Ford Pickup 1963 Lincoln Continental 1939 Buick Last edited by jrhaelig; 10-13-2014 at 06:55 AM. |
10-12-2014, 10:57 PM | #2 |
Re: #*&! Fuel Tank Replacement
Surprised, not me. I would assume that if someone is making a repro part and they have the part in front of them, the new part would be pretty damned close to the original. I guess not! They always change something whether it's a bolt size or thread or just a different size and then say "no one has complained before". Go figure.
10-13-2014, 08:36 AM | #3 |
jr,
I installed a Drake tank in my '41 1/2 ton prior to setting the bed in place. Afterward I discovered the Drake sending unit was no good so I decided to remove the tank and rework the sending unit flange for a Ford s/u. The tank was trapped by about 3/8". The 'kid' at Drake said this has never happened before and I must not know what I am doing. I made an adapter . I will drag this out a bit and tell you I did finally talk to Bob HIMSELF....he was attentive and offered a merchandise certificate to me. Big difference between the help and the MAN. Charlie ny |
10-13-2014, 10:38 AM | #4 |
"No one ever had that problem, before".
That is a stock reply from BD. MIKE (mikeburch) |
10-13-2014, 11:39 AM | #5 |
I put one of "Yogi's" plastic fuel tanks in my '47. The only hassle, of course, was removing the "cage nuts", otherwise, it slipped into place much easier than the other repros. The original tank had the usual pinholes from road crud collecting on the top.
10-13-2014, 03:51 PM | #6 |
10-13-2014, 04:01 PM | #7 |
I bought a 16-gal tank from Tanks, Inc. It fit my coupe OK, except the sending unit on the tank is not accessible from the stock opening ! You'd think they could punch the sending unit mounting hole it the correct position, wouldn't you ??
10-13-2014, 05:30 PM | #8 |
I got my steel tank from Drake for my '47 and it fit great. Had no problems.
10-13-2014, 06:34 PM | #9 |
I had the same problem with my 39 tank, the bottom half was shifted to filler side 1/4". I took 2 ball peen hammers and formed to get tank to move to left side more, then trim other side. I had just put body back on and wasn't going to take it off again.
That was the fix then remove body. Then the caged nut were to small. I guess those rejects are still around. |
