10-06-2016, 10:50 PM | #1 |
Access to Steering Box Sector Adjusting Screw
I've never seen a posting mentioning this issue.
The drivers-side exhaust manifold on the 59AB in my '47 sits directly above the sector gear adjusting screw with only about a 1 inch space between the two. Is this normal and is there a special tool for turning the adjusting screw ? The engine/frame/steering box layout is stock. Last edited by Drbrown; 10-06-2016 at 10:56 PM. |
10-07-2016, 09:33 AM | #2 |
Re: Access to Steering Box Sector Adjusting Screw
On my 39 I used a offset screwdriver and had to adj. it from under the car. Not easy.
10-07-2016, 09:45 AM | #3 |
On my '42 I also used an offset screwdiver to adjust. Did this from underneath the car.
Not a big deal. |
10-08-2016, 12:27 AM | #4 |
Made a screwdriver by grinding the short end of a 3/8 allen key easy as.
10-08-2016, 08:17 PM | #5 |
Thanks to all above. I'll try a few retailers for an offset otherwise I'm off to the grinder. Seems strange Henry Ford set this up this way Don't see anything mentioned in the Ford Service Bulletins.
10-08-2016, 10:29 PM | #6 | |
Again, not a big deal with the car in the air & proper tools. Last edited by 42merc; 10-08-2016 at 10:35 PM. |
