08-25-2016, 10:10 PM | #1 |
Float valve question
Does anyone know of a supplier that sells thin shims other than the usual one sold by the parts suppliers that could be used to shim the float vale accurately??
Thanks!!
Bob from Northport Northport, Michigan |
08-25-2016, 10:19 PM | #2 |
Re: Float valve question
just bend the float a little , if zenith sit top 1/2 in a beer glass , draw a line on beer glass 5/8" down , pour beer via a pipe soldered into an empty tinny , ajust float too the line , Drink the beer , all done .
08-26-2016, 03:46 AM | #3 |
Yes, you can gently bend float arm a little bit.
Or you can put some 400 grit sandpaper on a really flat surface (piece of glass) and gently rub a fiber washer on the paper to make it thinner. Go slowly and keep test fitting until you get float height you want.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
08-26-2016, 05:56 AM | #4 | |
Well, its good thing you're not wasting the beer afterwards ! |
08-26-2016, 09:20 AM | #5 |
I find the newer viton tipped float vales often need an extra washer or 1/2 thickness washer to get the hieght correct
08-26-2016, 12:09 PM | #6 |
08-26-2016, 02:46 PM | #7 |
Still waiting for them to arrive, Jim.
08-26-2016, 02:50 PM | #8 |
Bob, Bratton's catalog P.66, part #14341, float valve shim washers. $.95
08-26-2016, 04:58 PM | #9 |
Seriously!!!
I know they were sent airmail. (The pigeon may be on holiday in Hawaii on the way over the Pacific Ocean!) Perhaps MAFCA needs to adopt online voting instead of paper mail. That would save everyone a couple of stamps, and allow for faster and easier voting from our international members. Probably save the club some money, too! Well, whenever your ballots show up, please vote for me and send them right back so that they make the cut-off date of Oct. 15. Thanks!
