08-23-2016, 06:06 PM | #21 |
Re: Tires, a quick mounting question
On the goodyears the judges like the valve stem in between good---year then index the hubcap (ford) to the stem..
08-23-2016, 09:22 PM | #22 |
With today's tires and our 85+year wheels, I have found:
After 40 years with the dot in the valve-stem alignment, the tire show 1/8" wear. After 40 years with the dot opposite the valve-stem, the tire shows 1/8" wear. With the dot on the outside: 1/8" wear. With the dot on the inside: 1/8" wear. _________________________________________ Ignoring the initial reasoning for the placement of the tire's dot, today's alignment is truly aesthetic and a nod to historical accuracy. Ignoring it's practical irrelevance, I like to strive toward visual historic accuracy, and follow the guide as recommended by tire booklets of the 1920s and '30's, and use the dot as a 'balancing' mark. |
08-24-2016, 10:09 AM | #23 |
ALSO, pay attention to the little raised line on the tire, close to the rim, & see if the tire settled in on the rim properly. ALSO, set a jack stand close to the rim/tire, slowly rotate it & check for wobble/run out. Those tests take only a couple of minutes of your PRECIOUS time--LOL
Bill W.
08-24-2016, 10:24 AM | #24 |
Using tire soap helps the bead seat evenly plus allows the tire to slip on easier..
Don't do it dry...lube is your friend |
08-24-2016, 01:02 PM | #25 | |
Dad
08-25-2016, 08:45 AM | #26 | |
Squeaky tires rubbing the bead lol ... Learn something everyday.. Sonnnout |
08-25-2016, 10:34 AM | #27 | |
Quiet Dad
08-25-2016, 11:56 AM | #28 |
Yes they do, a lease when I had 16's on my Tudor. I had to tighten them every once in a while!
08-25-2016, 12:25 PM | #29 |
Yes hub cap squeaks I get all the time.... Bead squeaks never had one
