04-25-2014, 09:52 AM | #1 |
How to remove the Rear Pinion?
1938 stock rear-end. How do you get the pinion gear out of the case? I have everything else disassembled.
04-25-2014, 10:34 AM | #2 |
Re: How to remove the Rear Pinion?
It presses out, the setup is a bit difficult... I think that I have put the pinion upright in the press with a bar under the pinion, a couple of steel blocks on each side of the drive tube mounting flange and a plate over them...
And, I think that I've heard of guys who put a screw jack behind the pinion and the case to push the two away from each other. The screw jack would be a bolt and nut and a sleeve... Karl |
04-25-2014, 11:48 AM | #3 |
Warm the case with the rose-bud and slide it out.
04-25-2014, 02:01 PM | #4 |
I understand that it's bad practice to use a jack screw against the rear of the banjo casting. You just might break the casting. That said, here's how I did one. It's not pretty... The jack shown is a five ton jack that didn't cut it. The neighbor's ten ton jack worked.
04-25-2014, 03:43 PM | #5 |
I made my own pinion removal tooling using some scrap angle iron along with a jack screw and the center portion of a pulley puller. Leave the pinion gear assembled. You can remove the bearing lock nut, as it is easier to brake the torque of the nuts with the pinion pack installed in the banjo case. The jack screw is pressed against the pinion gear pilot to push the whole pinion gear pack out. The press fit of the banjo case and outer race of the pinion bearing is .003 to .005. A minimal amount of force is required to press this bearing race out.
Good Luck, Norm |
04-26-2014, 10:04 AM | #6 |
04-26-2014, 10:16 AM | #7 |
When you are putting it all back together a freezer and wood-burning stove
can make it easy. The pinion bearing and entire pinion assembly fell into place for me. I had to remove a small amount of material off the new pinion surface for the forward bearing so that it could slip enough to adjust the drag.
[FONT=Comic Sans MS] |
04-26-2014, 06:23 PM | #8 |
Amen to this. I didn't realize that I had to do this and had a heck of a time getting the preload adjusted!
04-26-2014, 08:51 PM | #9 | |
05-02-2014, 08:44 PM | #10 |
Here is a picture of the tool that I have for removing the pinion assembly.
05-02-2014, 11:21 PM | #11 |
I built an elaborate jig assembly to install the bearing. The banjo came out of hot oil into the jig, pinion and bearing from the freezer, assemble the jig, one blow with a BFH sent the jig in all directions, and the job was done. I never knew if I needed all that, but overkill better than half kill.
To adjust the preload, put the assembly into a large vise banjo up, shaft down. Spin the banjo with both hands as fast as you can. The preload is correct when the banjo will spin just one full revolution when you let it go. For the doubters, ask any of the old timers. This is the preferred method from way back.
Alan |
05-30-2023, 03:55 PM | #12 |
Dear all, I'm just in the process of overhauling the rear axle of an early ford V8, all parts came out OK, except the pinion gear. I wondered how to get it out........, now I know!
Many thanks ( the rear axle is part of an Ford based Indy race car which I found in Manila some years ago, this car was made in the early 50's ) |
05-30-2023, 06:21 PM | #13 |
They do press out if you support the back of the pinion and push down on the housing with a piece of pipe large enough for the pinion bearing to slide up into. Ford had a fixture that the housing sat on. Then thew blew heat into the fixture with one of those old-fashioned hand blow torches every grandpa had in their garages. I inherited one and I still don't know it works. If they thought, it was okay to heat the housing to put the pinion in it must be okay to heat around the outside to it take it out. No more heat than necessary or you can change the metallurgy of the metal. Always let it cool slowly.
