04-23-2014, 12:34 PM | #81 |
Re: Vapor lock 1 and 2
The most typical problem with vapor lock is vaporization of the fuel in the fuel pump, not total boiling out of the fuel in the carburetor bowl. Anyone that's ever had vapor lock knows that if you wait long enough the fuel pump will cool down enough to condense the fuel back into liquid so that the pump will pump. (That can even be rushed by pouring water on the pump, pushing a half grapefruit onto the top of the pump, etc). So, overheating the engine then leaving it all night is, of course, going to allow the pump to cool and condense the fuel and have no problems starting in the morning. The true test would be taking a 30 mile drive in 90+ temperatures, stopping and parking in the sun without opening the hood for 20 minutes, then starting up and seeing what happens. I look forward to the results of that test. Let us know how it goes.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
04-23-2014, 01:18 PM | #82 | |
VL-2 was fuel vaporizing in the fuel pump when the fuel pump gets between 130 and 135 at the top above the diaphragm where the fuel is. Driving the car, getting it hot and letting it sit in no difference than getting it even hotter in the garage and letting it set for a period of time and restarting. I will be driving it later this week and will report back but the results will be the same as last nights findings. Static tests on some problems are sometimes better than driving, the conditions are controlled and the same each time. G.M.
www.fordcollector.com |
04-23-2014, 02:07 PM | #83 |
who sales the shewman"s ventilated spacer. does anyone have a contact. i installed the airtex fuel pump and would like to have the spacer to.
04-23-2014, 02:09 PM | #84 |
I installed the spacer but it didn't do me any good because the heat that affects the carburetor after shut down is coming from the hot air under the hood in the engine compartment as much as from the hot engine block.
04-23-2014, 02:13 PM | #85 | |
04-23-2014, 03:53 PM | #86 |
04-23-2014, 04:10 PM | #87 |
Fuel can't syphon through the air it the top of the carb fuel bowl. It would have to be pressurized at the bottom to raise the fuel then the needle valve would close??? G.M.
04-23-2014, 04:15 PM | #88 |
I don't believe it. Everyone else who used Bob Shewman's 1/2" vented spacer got results. But of course your one of the few that his thermostats didn't work either. You had a crusade against any product Bob made on this fourum before you ever had them?? What seems to be your game?? G.M.
04-23-2014, 04:24 PM | #89 | |
04-23-2014, 04:34 PM | #90 | |
Right you are.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 04-23-2014 at 04:41 PM. |
04-23-2014, 04:37 PM | #91 | |
[email protected] Your talking about an Airtex fuel pump which is just like the original Ford pump. This has nothing to do with preventing vapor lock. I put a return fuel line in the pump to carb line using an Airtex fuel check valve on the return line. This allows a portion of cold fuel from the tank to keep circulating through the fuel pump cooling it as it returns through the return line back to the tank. G.M.
04-23-2014, 07:30 PM | #92 |
Going by some earlier posts on this thread you can see that some people beleave just that ! .That that the carb bowl can empty out by draining back .Has any one bothered to lift the carb top to see the fuel level in a vapour lock situation ?
04-23-2014, 07:42 PM | #93 |
Ted since you brought it up that would be a good project for you. Please report the results. G.M.
04-23-2014, 09:26 PM | #94 |
The engine doesn't die immediately when the fuel pump vapor locks and stops pumping. It will continue to run until the gas is all gone from the carburetor and the fuel pump isn't replacing it. That's when the engine dies and won't start again until some gas is pumped into the carb either by cooling the mechanical pump to get the gas vapor to condense back into liquid so that it will pump again or by pumping gas into the carb with an auxiliary electric pump. So, when the engine dies, obviously there is no gas in the carburetor bowl. If there was, the engine wouldn't die. Don't need to take the top off of the carburetor nor have a sight glass on the carburetor to know that. It's common sense.
04-23-2014, 11:57 PM | #95 |
If this were a democracy, I'd vote to close this thread. No, we're not having fun here.
Alan |
04-24-2014, 03:17 AM | #96 | |
GM I might take you up on that .
What I cannot understand is how can a electric pump works but a mechanical one doesn't ,since they both have a diaphragm. Keep up the good work with your road trips . Last edited by FlatheadTed; 04-28-2014 at 02:07 PM. |
04-24-2014, 03:37 AM | #97 |
Flathead Ted:
It's the locatation of the pump's The Mechanical pump is on the motor, ( Picking up the heat of the motor )while the electric is near the fuel tank, (a much cooler area ) I don't know if any one has tried to heat up the electrical pump but More then likely It would not pump. |
04-24-2014, 05:00 AM | #98 |
Stop reading it then. Simple enough.
I dig coal, which provides motivation for EVs. |
04-24-2014, 08:44 AM | #99 | |
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 04-24-2014 at 09:13 AM. |
04-24-2014, 11:14 AM | #100 |
that is probably one of the reasons alot of manufactures started placing the pumps inside the fuel tanks. to get them away from the heat of the motor and to have the gas keep them cooled.
another thought: with the c***y motor, the pump is mounted low on the right front of the motor and that provides a place in directly in the flow of cooler air and puts the pump at the same aproxamate level as the gas tank so it does not have the inhearent problems of the ford's placement that has to pull fuel up to the top of a hot motor where the fuel pump sits captive in non flowing hot air. i do have a GM motor in my 50 and run a stock GM fuel pump on the right front in the air flow, the fuel line has been re-routed down to frame level. the motor has a 195 thermostat and AC and so runs at the 200+ degree range i have never have any problem with vapor lock. i believe that if a person is one is going to use a stock ford fuel pump on top of a hot motor, at some point they probably will experience vapor lock. rather than going through all this "experimentation" of fuel return lines, check valves and everything else being expereminted here in this thread, doing what Old Henry has done, installing an in line, pull thru axuxilary pump down low on the frame, in the cool air flow and at the same level as the fuel tank, with a "when needed" switch (what i did on my other 50s and 41 PU) is a simple and effective souloution to this issue. it just seems to me that what has been said here on this thread, the cure seems to be "over engineering" at it best. there is a simple souloution avalable without going overboard.. just my thought... don |
Thread Tools | |
Display Modes | |
