06-01-2013, 08:04 PM | #1 |
Finish on spring clips
06-01-2013, 08:51 PM | #2 |
Re: Finish on spring clips
Look at the UNDER CARRIAGE FINISHES table on page 4-22 revised 2011 under “Spring Clips' they are are "BG".
Under codes BG = black gloss
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
06-01-2013, 09:28 PM | #3 |
I saw the spring clip finish as satin black paint, but I need the bolts and nuts finish.
Rusty Nelson |
06-01-2013, 09:47 PM | #4 |
I looked again and
Spring Clips, front ("U" bolts are "Bg" and the Nuts are U2, Bg and cotters are "U" Spring Clips, rear ("U" bolts are "Bg" and the Nuts and cotters are "U" Bg Black Gloss U2 Change date mid 1930
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 06-01-2013 at 09:54 PM. |
06-02-2013, 12:17 AM | #5 |
I believe the U bolts and nuts are the parts that hold the springs to the front and rear crossmembers, not the clip bolts and nuts I was referring to. There are no cotter pins used on the spring clip bolts and nuts.
Rusty Nelson |
06-02-2013, 01:41 AM | #6 |
My thoughts have been that they were assembles with the spring and painted as a complete unit, making them black satin. |
06-02-2013, 07:31 AM | #7 |
Gary,
Thanks for the info. I had a slight suspicion that might be the way it was originally done by Ford, but didn't see anything in the JG's. Your help is appreciated. Rusty |
06-02-2013, 03:07 PM | #8 |
Now I understand, you want the finish on the spring clamps, and the response from Gary Karr is right on. The spring clamps should be the same as the spring, "Bst" black satin.
