04-08-2013, 08:47 AM | #1 |
Footrest question
I have a nice newly replated original footrest that I need to install a rubber insert into. I got several exact reproduction rubber inserts from Doc Kalinka. However, I tried to push them into the opening in the metal footrest with no luck. I am hoping someone on Fordbarn has successfully installed rubber inserts into footrests. I was thinking of putting the rubber into boiling water or in the oven (temperature??) for a while to hopefully soften the rubber to make it easier to install. Maybe a rubber lubricant would help. I don't want to ruin the inserts as the ones I bought from Doc are the last he has. Any help would be appreciated.
Rusty Nelson |
04-08-2013, 09:30 AM | #2 |
Re: Footrest question
Try soap and water or a light coat of oil may help
kevin |
04-08-2013, 10:36 AM | #3 |
No experience here...but I wonder if heating the footrest would expand it just enough to let it squeeze and also allow it to melt and cool with a tighter fit? Not sure of it would damage the pad from the heat when you tried to squeeze it into a the hot footrest...possibly a combination of a non-flammable lubricant and heat?
george |
04-08-2013, 10:43 AM | #4 |
Rusty, I cannot tell if that is an Early V-8 or a repro but the originals are a tad larger in diameter in the recess. An easy way to tell the V-8 is the stem is a little longer. As for installation, heat the urethane piece you got from Doc in a microwave for 20-30 seconds to make it pliable but remember you need to cement that in so be careful and not use something on the urethane that would counteract the cement glue.
04-08-2013, 11:09 AM | #5 |
A little off topic but I can not figure the purpose for the foot rest
04-08-2013, 11:14 AM | #6 |
04-08-2013, 11:29 AM | #7 |
Aok, the footrest helps you ease on the gas and not start out from stops like a bucking bronc also it does as it is called and allows your leg to rest as you are driving. Without it would be like sitting in a chair with out a back, after a while you would tire out.
04-08-2013, 11:36 AM | #8 |
Aok, if you drive over a ruff area you will see the need for the foot rest. If you do not have it, your foot will be pushing and letting up on the gas as you go along. Also J Franklin has another good reason for it.
You do need to adjust it for your way of driving. That is how high or low do you need it to have you foot rest on the gas the way it would work best for you.
Fred Kroon 1929 Std Coupe 1929 Huckster |
04-08-2013, 11:39 AM | #9 |
I used WD 40 and they slipped on with very little effort.
Al |
04-08-2013, 03:30 PM | #10 |
I guess I need to drive some more to see the need for foot rest as has been explained. It seems to be too far away to be useful when driving but right now I have the upper floor out as it was hanging up the clutch pedal.
I had the car about a year but not much driving last do to engine problems. New engine in now so plan to get a lot more road time this year. |
04-08-2013, 04:04 PM | #11 |
The bottom edge goes into the recess so if you were to take a little off the bottom, round it off a little, it may slip in easier.
04-08-2013, 08:29 PM | #12 | |
I removed the foot rest from my car and ordered the new front carpeting without the ginormous hole in it, then made a small hole for just the gas pedal. Now, it's NICE! The footrest will not be going back in the car. It's in a plastic bag of "extra" parts for the car, and there it will remain. |
04-08-2013, 09:27 PM | #13 |
Did you turn it inside out, lay on top of piece and roll it over, try it, this is how I put the ball on the wishbone, it just might work here.
04-08-2013, 09:39 PM | #14 |
04-08-2013, 09:50 PM | #15 |
Sorry, thought it was a cover, I have no clue, did you contact the vender, maybe they can give you some help. Good luck, if you find a way, let us know!!
04-08-2013, 09:52 PM | #16 |
I have made several "tools" for pushing rubber into smaller holes out of old alarm speakers ---the kind used in car alarms, in the center is a tapered aluminum cone, cut it off at the diameter that fits inside the metal part ---on some parts that take a lot of fforce to push through i will reinforce it with bondo in a can ---by making a hole in the bottom of a small can, pouring bondo in the space between the cone and can to support the thin cone ---then lube the rubber and push it into the smaller hole, hold the rubber in place and pull off the tool ---works good for suspension bushings, and mounts that have to be forced in.
I like having the footrest, it puts me in driving "A" mode, sort of a rolling twisting motion instead of the modern up-down --makes it easy to have smooth pedal control no matter how rough of a road |
04-08-2013, 09:54 PM | #17 |
Don't stab your finger trying to push it in! Drill a hole into a piece of wood, so you have something to hold the metal piece.
