06-29-2021, 07:43 AM | #1 |
50 Ford Overdrive/Driveshaft
I am guessing that I will need a shorter driveshaft for 1950 overdrive transmission than for non overdrive transmission?
Steve |
06-29-2021, 07:56 AM | #2 |
Re: 50 Ford Overdrive/Driveshaft
They are the same. So is the motor mount, you just need to turn it around.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
06-29-2021, 08:21 AM | #3 |
Whew, that's good. Tail shaft length is the same just different mount location?
These electric or manual activation? On the dash..or under..? I am about to convert from regular trans to OD. Thanks, Steve |
06-29-2021, 09:40 AM | #4 |
