03-30-2020, 12:04 AM | #1 |
Rear panhard rod 39 merc
just curious can anyone say how common the rear panhard rod is on these seen a few all had front bars but only seen one with rear
03-30-2020, 12:49 AM | #2 |
Re: Rear panhard rod 39 merc
I'm not certain, but I think they started in 1940.
Alan |
03-30-2020, 07:44 AM | #3 |
As a 39 Merc owner myself, would be real interested in a rear sway bar application! Anyone have more info?
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
03-30-2020, 08:56 AM | #4 |
03-30-2020, 11:41 AM | #5 |
You don't see them on the rear very often as they were never installed at the factory.
03-30-2020, 11:44 AM | #6 |
03-30-2020, 12:20 PM | #7 |
Ford prepped for a rear axle track bar or panhard bar in 1941 and I think they may have been used in 1942 for sedan delivery and station wagons but production was cut short. They were definitely in post war production for passenger cars.
03-30-2020, 09:48 PM | #8 |
hey shoebox dont know about a rear bar but i fitted a pete and jakes front bar backed the front shocks off to a 1/4 took the rears up to 5/8 boy did that make a differance im still running crossplys any tighter in the rear might drag the tyres
03-31-2020, 08:59 AM | #9 |
My '46 Super Deluxe Coupe (late year build based on S/N) has a panhard bar.
03-31-2020, 01:30 PM | #10 |
My 40 MERC has front and rear.
03-31-2020, 03:25 PM | #11 |
03-31-2020, 10:19 PM | #12 |
Kube, If I said rear sway bar would you be happy?
04-01-2020, 08:21 AM | #13 |
Good morning Clem. I am happy You?
Call it whatever you or others may so desire. Your Merc did not leave the factory with a rear "sway" bar.
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 04-01-2020 at 08:44 AM. Reason: spelling correction |
04-01-2020, 08:26 AM | #14 |
thanks. I'll look a bit. Clem
04-01-2020, 07:55 PM | #15 |
Kube
Of course, you were correct. I bow to the Master. Back in 1956 I put a sway bar on my that 40merc. I had 6 inch shackles to lower the rear end and she needed a rear sway bar. The 40Merc now does have a front bar. double thanks to you for steering me to crawling under the 40Merc which I love to do to any car. The left rear shock arm had the link straight away from the shock arm...Not right. Link threads were damaged. Fixed but not installed. Clem kube |
04-02-2020, 03:54 AM | #16 |
Some early speed catalogs offered them in conjunction with long rear shackles for lowering.
Long rear shackles without a sway bar and there's never a dull moment. Like a labrador on linoleum |
04-02-2020, 08:18 AM | #17 | |
We have three Labs. Love em all. When they come in for dinner - we step aside. They go around the corner in the living area so fast they at times tip over sideways. I think I should build a "banked curve" in to the hardwood floor. Thanks for the smile!!!
04-02-2020, 12:45 PM | #18 |
yes. there is a story about long shackles,a gun, girls and night time...
04-02-2020, 04:21 PM | #19 |
longer shackles that could prove interesting as i can actually feel a certain amount of shackle shimmy with standards I guess thats why they recommend to install tube shocks at an angel so as to control this as well as vertical movement
04-02-2020, 05:34 PM | #20 |
By themselves, tube shocks at an angle don't help much when you have long shackles.
Don't ask me how I know |
Thread Tools | |
Display Modes | |
