Old 10-23-2021, 08:21 PM   #1
Smitty
Smitty's Avatar
Default 1950 Ford Passenger Car Hood Latch
Hi All,Any tips, tricks on how to adjust the hood latch? If I remove the latch the hood aligns just about perfect. Soon as I install the latch the hood does not want to close completely or sometimes the hood will catch and it does not want to release even with the hood release cable pulled.
Any thoughts, Thanks, Steve
Smitty is offline   Reply With Quote
Old 10-24-2021, 09:13 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 1950 Ford Passenger Car Hood Latch
Generally the latch has little to do with hood alignment.
The spring loaded spike can be adjusted to correct most problems but sometime it is necessary to adjust the radiator core support.
Old 10-24-2021, 09:28 AM   #3
RalphG
RalphG's Avatar
This is something I need to check out on the 52 Merc. Ever since I installed the hood and fenders from my 53 parts car I have noticed a slight misalignment of the hood with a larger gap on one side than the other. I could not see any adjustments on the hood to move it to one side or the other but maybe this spring loaded spike can pull the hood into alignment.
RalphG is offline   Reply With Quote
Old 10-24-2021, 11:17 AM   #4
Smitty
Smitty's Avatar
When I remove the spike the hood seems to close correctly with proper fit. I will try and gently bend the spike.
There should be no issue with the spring being strong enough, should not weaken over time...?
Old 10-24-2021, 11:43 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Keep in mind that you are not trying to bend the spike but the sheet metal that it is attached to.
And yes. there is a possibility that the spring is weak.
To rectify weak spring, suitable washer/s can be added to increase pressure.
Old 10-26-2021, 08:48 AM   #6
Smitty
Smitty's Avatar
51 Merc,
Great idea, thanks.
Steve
