02-20-2017, 06:42 PM | #1 |
Motor Mount rubber
Would like to know the correct thickness of the flat rubber between the original mounts and frame; the vendors pads appear to be too thick.
02-20-2017, 06:46 PM | #2 |
Re: Motor Mount rubber
FWIW, I just installed a new set, and it went together fine. Pretty sure I got them from Brattons.
02-20-2017, 06:48 PM | #3 |
I don't have the dimensions but the ones I got from Brattons about 2 years ago were too thick. Ordered from Snyder's and they fit perfectly.
I Love Anything That Turns Money Into Noise |
02-20-2017, 06:50 PM | #4 |
mine from snyder a year ago were fine.
02-20-2017, 07:00 PM | #5 |
Remember,they're not just flat pads.They have little sleeves molded onto the three holes that fit through the frame.
02-20-2017, 07:30 PM | #6 |
02-20-2017, 09:06 PM | #7 |
The ones I got from Brattons were to thick and to hard...The ones I got from Snyders were perfect.
Pluck |
02-20-2017, 09:09 PM | #8 |
My experience also: Bratton's were too thick, Snyders were a good fit.
02-20-2017, 10:43 PM | #9 |
I installed the Snyder's rubber last week and slide the engine in place with only a little help from my teenaged son. They fit great
Eat more large Lima beans!! |
02-20-2017, 11:54 PM | #10 | |
The engine dropped right in without a frame jack or any adjustments to the engine mount assemblies
Good enough.. Isn't. |
02-21-2017, 12:09 AM | #11 |
Too thick or too thick for your car?
"The rubber pads between the rear motor mount to frame and frame to support mounting plates. 4 pieces. Unlike others on the market ours are made to the original blue prints." motor-mount-pads
02-21-2017, 12:25 AM | #12 | |
The last 3 sets I bought from Snyder's over 5 years have been a perfect fit. |
02-21-2017, 07:07 AM | #13 |
That is what I said,or,at least,it's what I was trying to say.
02-21-2017, 11:17 AM | #14 |
Have a set that came in an extra parts box and seem to be very thick and not sure where they came from. Just would like a thickness dimension of some inner pads that work. I guess we'll try the vendors. BTW, we are so fortunate that there are excellent vendors with parts for our cars. Try to find spider gears for mid to late '20's De Sotos !!
02-21-2017, 04:34 PM | #15 |
For the Snyders parts, the sleeves are not "molded in" the rubber. They are loose and must be installed before final assembly.
Sam Ting.. Maybe my old eyes are getting worse..
02-21-2017, 05:29 PM | #16 |
I guess I've never seen them like that.All the ones I've used have half the rubber sleeve molded on one part,and the other half on the other.Then they meet somewhere in the middle of the frame and the little steel bushing pushes through the two halves.
02-21-2017, 05:46 PM | #17 |
Here are two photos of rubber pads that I photographed several years ago. The thin ones were very old, and the thick ones were what was being offered at the time.
02-22-2017, 01:53 PM | #18 |
thank you 2many; that 's kind of what I remember from originals tossed. It's the inside frame rubber that is too thick.
02-22-2017, 06:11 PM | #19 |
Spread the frame slightly , port-a- power of make one with threaded rod and a pipe. Don't need much , thick or thin .......
"I can't cry as long as I know the Lord has risen " |
