Old 11-04-2012, 09:25 AM   #1
36coupe
36coupe's Avatar
Default 35 & 36 waterfall dashes
Are 35 and 36 waterfall dashes different?
Are they interchangeable?
Are the dashes themselves the same?
Thanks
Lindsay
36coupe is offline   Reply With Quote
Old 11-04-2012, 10:07 AM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: 35 & 36 waterfall dashes
Depending on which models of those two years you are talking about....the bare dashes (for say the closed cars) would be the same but waterfalls would be different for '35 vs. '36. I have three standard model '35's that did not get a waterfall as they came off the assembly line (tudor sedan, fordor sedan and 5w coupe). I could put pictures up of '35 and '36 closed car waterfalls if you need to see the difference or you could look in the EFV8C/A 1935-36 Ford Book.
John
Old 11-04-2012, 10:09 AM   #3
ken ct
35+36 will interchange but are not same. roadster and cabrolet have NO crank hole. ken ct.
ken ct is offline   Reply With Quote
Old 11-04-2012, 10:43 AM   #4
DavidG
DavidG's Avatar
'35-'36 phaetons and roadsters have no 'waterfalls'; only cars with roll-up windows have them.
Old 11-04-2012, 10:44 AM   #5
deuce lover
deuce lover's Avatar
Roadsters and phaeton do not have the waterfall.
deuce lover is offline   Reply With Quote
Old 11-04-2012, 03:06 PM   #6
Mike in AZ
Mike in AZ's Avatar
i saw a late '36 dash today....i think....had a raised area around the crank hole.....figured it was late as pictured in the '35-'36 book, which shows the late dash as having a chrome ring around that hole and 2 "narrow stainless strips on either side of the center ash receptacle hole".....so now waterfall on that dash....Mike
Mike in AZ is offline   Reply With Quote
Old 11-04-2012, 03:17 PM   #7
Don Rogers
Don Rogers's Avatar
Lindsay, Here is a comparison of the 35 and 36 waterfall. It also shows the difference between closed car waterfalls and Cabriolet, Woodie & Conv. Sedan waterfalls.
Hope this helps
Don Rogers is offline   Reply With Quote
Old 11-04-2012, 03:34 PM   #8
36coupe
36coupe's Avatar
Okay, thanks. Now I see the difference. Being that I have 36 5 window I will need one with the crank hole.
Thanks for the replies.
Lindsay
Old 11-04-2012, 03:34 PM   #9
36coupe
36coupe's Avatar
Lindsay
Old 11-05-2012, 12:40 PM   #10
Rusk
Rusk's Avatar
A question on this topic......I've seen the waterfalls painted between the ribs and chromed (or polished stainless?). How did they come from the factory?
Rusk is offline   Reply With Quote
Old 11-05-2012, 03:06 PM   #11
FL&WVMIKE
FL&WVMIKE's Avatar
Here is a photo of an original, with original paint, Waterfall used on Cabriolets, Convertible Sedans and Station Wagons for 1935.
MIKE
CLICK ON PHOTO TO ENLARGE - Twice.
FL&WVMIKE is offline   Reply With Quote
Old 11-05-2012, 03:39 PM   #12
36coupe
36coupe's Avatar
I guess that would mean there are 4 different types.
Old 11-06-2012, 11:54 AM   #13
blucar
blucar's Avatar
The original waterfalls were always painted with just the raised ribs being chrome..
As time went bye, many people removed the paint, exposing the chrome..
Bill.... 36 5 win cpe
Old 11-06-2012, 11:58 AM   #14
blucar
blucar's Avatar
No, just three... '35 -'36 and the open car variation..
Of course the painted portion varied depending on the variations in dash paint colors...
Old 11-06-2012, 12:05 PM   #15
FL&WVMIKE
FL&WVMIKE's Avatar
blucar .....................
Wouldn't there be four ?
1. You have 1935 NO crank hole.
2. You have 1935 with crank hole.
3. you have 1936 NO crank hole.
4. You have 1936 with crank hole.
MIKE
Old 11-06-2012, 05:00 PM   #16
Django
Django's Avatar
Aren't the cabriolet waterfalls a little deeper too, besides not having a crank hole?
Obsessed with all things 1936 Ford since birth... thanks Dad.
Django is offline   Reply With Quote
