06-09-2020, 07:27 PM | #21 |
Re: KR Wilson Steering wheel puller
What is the part number of the perch pin press. If they still make it I want one.
06-09-2020, 08:02 PM | #22 |
Thank you skidmarks!, now I know what else to watch for.
06-09-2020, 08:23 PM | #23 |
Correction on the perch bolt press kit number. CG-220-A
06-10-2020, 05:08 AM | #24 |
06-10-2020, 06:49 AM | #25 |
Interesting perch pin pusher. I wonder how it would work today now the pins have been in for probably half a century longer. I have a puller tool that I made, but I bet if you used the pusher and puller at the same time it would be easier still.
Mart. |
06-10-2020, 08:29 AM | #26 | |
I can tell you that the Snap-On that pin press/puller we have has not met a pin that can beat it in our little garage. I've used it at least a dozen times. It may start slow, but once it gets movement on the pin, the pin slides out with ease. The pictures don't do it justice. The one we have (newer version -20 years old) is heavy. It must weight 15-20 lbs. It built like a brick poop house. |
01-08-2021, 06:14 AM | #27 |
That Snap-On Universal Steering Wheel Puller that Skidmarks showed in Post 19 looks to be a great asset in the home garage. |
01-08-2021, 08:57 AM | #28 |
