Old 07-03-2021, 06:23 AM   #1
deuce lover
deuce lover's Avatar
Default Check this Flatty out
Not mine and stunning!. A friend sent me this pic.If I only had the means.
Old 07-03-2021, 06:27 AM   #2
miniceptor86
miniceptor86's Avatar
Default Re: Check this Flatty out
It’s not gunna run that way!
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 07-03-2021, 07:50 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
That must be because of the sea-foam green paint and the yellow plug wires! LOL
Old 07-03-2021, 08:31 AM   #4
deuce lover
He forgot to connect the coils
Old 07-03-2021, 08:33 AM   #5
Charlie ny
Outrageously delightful,,,,,,,,it appears as though it is destined for '39 - '41. Loose the
set back intake and go for the Offy clone Speedway 910-15985 CENTER mount 2x2
and 8BA pumps. Allows room for a center mount gen and tucks in w/ room to spare.
Only my biased opinion.
Charlie ny
Old 07-03-2021, 08:46 AM   #6
CA Victoria
CA Victoria's Avatar
The distributor conversion is interesting, any discussion on it?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 07-03-2021, 09:20 AM   #7
deuce lover
I wish I knew more.All that was noted were the ELCO TWIN heads. Curious also as to what the ign is.Looks like SCOT tops on the carbs.
Old 07-03-2021, 09:33 AM   #8
deuce_roadster
deuce_roadster's Avatar
I see a lot of money there. Pretty cool.
Old 07-03-2021, 09:59 AM   #9
earlyride
earlyride's Avatar
I think, not sure, but the distributor could be a nash twin 8 from the 30's
earlyride is offline   Reply With Quote
Old 07-03-2021, 10:03 AM   #10
19Fordy
19Fordy's Avatar
If you have enough dough, you can make it go. Looks nice.
Old 07-03-2021, 11:33 AM   #11
vilanar
Yes, distributor is NashTwin8 and they had plans to reproduce it but I think it newer happened...
vilanar is offline   Reply With Quote
Old 07-03-2021, 11:40 AM   #12
19Fordy
19Fordy's Avatar
Here's some interesting reading about 'reproducing" the twin 8.
https://www.fordbarn.com/forum/showt...0934&showall=1
And more: Parts are pricey, if available. Check this out.
https://www.google.com/search?q=twin...hrome&ie=UTF-8
Old 07-03-2021, 11:57 AM   #13
Bored&Stroked
Given the horsepower and fuel requirements of almost any engine we'd run in any of our hotrods, there would be extremely negligible increases in HP with dual plugs. Outside of reliability goals (dual coils, dual plugs), I can see no value other than bragging rights.
Now, on modern top-fuel Hemi engines making 8000 HP+, there is a need . . . but that is about it.
Old 07-03-2021, 12:38 PM   #14
KiWinUS
KiWinUS's Avatar
Dale the “Kool” factor is way over the top. Looks fast sitting still.
Old 07-03-2021, 02:09 PM   #15
V8COOPMAN
V8COOPMAN's Avatar
A 'beaut', for sure! But it would look just as fast, yet with way more class if that ghastly yellow was on somebody else's Chevy engine. DD
Click Links Below __
T5 W/TORQUE TUBE
V8COOPMAN is online now   Reply With Quote
Old 07-03-2021, 02:29 PM   #16
KiWinUS
KiWinUS's Avatar
LOL OH so true DD.
Old 07-04-2021, 09:04 AM   #17
JSeery
JSeery's Avatar
Be interesting to see the dyno differences between a one vs two plug arrangement per cylinder. I know on a small aircraft you can tell the difference when you do the ignition test and switch between the magnetos.
