04-29-2024, 11:58 AM | #21 | |
Re: Running ford king seeley gauges on 12 v
I am not sure about the accuracy either, but it may be the way it works. I hope someone does the test suggested above. |
04-29-2024, 11:59 AM | #22 |
My experience has been that operating stock 6V KS gauges on 12V (not reduced to 6V)
will ruin the gauges. That's why a voltage reducer is needed. |
05-01-2024, 09:51 PM | #23 |
I used the attached pdf and made my own 12V to 6V regulator for the gauges in my 53 sedan. It has been working well for a decade of driving and 30k miles.
05-02-2024, 10:11 AM | #24 |
Steve: Thanks for sharing your PDF and knowledge. Very informative and helpful.
05-02-2024, 08:26 PM | #25 |
I have been doing the gauge thing for more years than I care to remember. All Ford factory gouges, and I mean ALL, except for charge/battery condition gauges are 6 volt until 1986. I worked most of my life if Ford dealers. Not to mention my passion for old Fords that started in ernest when I bought my first car, a 48 Ford couple in 1962 at the age of 14.in 1986 Ford went to the GM style magnetic gauges and we had terrible headaches with them at first. Up to that time. Ford used 6 volt King Selley gauges and à cluster voltage regulator that supplied pulsed 6 volts to the gauges. I have many times taken a later gauge and by swapping faces and needles, installed it in a 40's model Ford without problems or inaccuracies. King Seeley gauges do not work on voltage, but rather a heated bi-metal strip between the needle and contacts on the gauge. The exact same system was used on the 6 volt systems until 1985, 3xcept when they experimented and failed using direct 12 volt gauges. By using the cluster or instrument voltage regulator they kept the 6 volt system working quite well. I worked tune up, a/c, and electrical in Ford dealers from the early 70s through the 90s. Mostly in that capacity. Plus the time spent working on my and friends/side work customer's cars. In an unbelievable moment of lack of wisdom,Ford decided that they would follow in GMs footsteps and ended up with a disaster in 1986. I hope that I have adequately explained the King Seeley gauge history and operations.
05-02-2024, 11:10 PM | #26 |
