Old 08-01-2020, 12:05 AM   #1
totto
totto's Avatar
Default 1934 pickup horn : Who repairs these Sparton hornss
Looking for someone who repairs Sparton vibrator horns.
totto is offline   Reply With Quote
Old 08-01-2020, 09:35 AM   #2
G.M.
Default Re: 1934 pickup horn : Who repairs these Sparton hornss
Any electric motor repair shop could check them
and rewire if required G.M.
www.fordcollector.com
Old 08-01-2020, 09:55 AM   #3
TJ
TJ's Avatar
Remove the cover and clean the inside with electrical contact spray cleaner. Sometimes it's just a matter of dirty contacts.
Old 08-01-2020, 10:36 AM   #4
rotorwrench
rotorwrench's Avatar
Corrosion of internals and mountings are the biggest killers of horns. If the parts are all intact with little or no corrosion then it would likely only need careful cleaning of the vibrator points. If the vibrator coil goes bad, they can generally be rewound as long as the same gauge wire with the same number of turns is utilized. These things were factory set to pull a set amount of amperage so be careful with adjustments unless you know what the OEM specs are. There are likely several shops out there that can rebuild horn vibrators. A search of the early V8 club magazine or Hemmings should bring up a few.
Old 08-02-2020, 10:30 AM   #5
32phil
At one time there was an outfit called
The Horn Shop
They were in Rome, New York
Unfortunately, I have other info
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 08-02-2020, 10:34 AM   #6
V8ER
The Horn Shop is closed. Bill died several years ago.
V8ER is offline   Reply With Quote
Old 08-02-2020, 05:18 PM   #7
FlatheadTed
FlatheadTed's Avatar
They share the same internals as 32,to at least 36 .so a swape out could be a simple solution .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-02-2020, 05:30 PM   #8
koates
Just touch up the contacts with a points file or a strip of doubled over wet and dry paper, not emery and clean off residue with contact cleaner pressure spray can. DONT MESS WITH ANY OF THE ADJUSTMENTS. Most likely a new condenser will be required. Condenser is .2 mfd, 400 volts. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-04-2020, 12:40 PM   #9
totto
totto's Avatar
THANKS for all the input/response, will try to "clean" contacts and wiring.
Henry
