Old 06-30-2022, 05:28 PM   #1
GT1929
Default Oil Filler
Oil Filler tube came out while driving found it on road when returning. I didn't lose much oil although plenty splashed around engine and firewall.
Have put it back in hope it doesn't happen again. Any suggestions how to stop this?
GT1929 is offline   Reply With Quote
Old 06-30-2022, 07:03 PM   #2
nkaminar
nkaminar's Avatar
Default Re: Oil Filler
Normally a light press fit. Try expanding the bottom part of the tube by hammering on it while it is on a mandrel. Any round steel part, mounted in a vice, can be the mandrel. The hammering will expand the metal.
Or glue it in with a loctite adhesive or other adhesive. If you use the adhesive clean everything with acetone.
Old 06-30-2022, 07:21 PM   #3
Ian in Mississauga
When I had that problem I tinned the tube with soft solder (tin and lead).
Ian in Mississauga is offline   Reply With Quote
Old 07-01-2022, 07:45 AM   #4
marty in Ohio
marty in Ohio's Avatar
Mine was loose but it didn't fall out. I did what nkaminar described and it worked fine.
Marty
marty in Ohio is offline   Reply With Quote
Old 07-01-2022, 10:46 AM   #5
katy
katy's Avatar
After you re-install the tube, lay a piece of 2X4 across it and tap it down w/a 3 or 5 lb hammer.
Old 07-02-2022, 01:27 AM   #6
GT1929
Hello,
Thanks have tapped it down with a piece of 4x2 (that's how we describe it in NZ) and hammer. Took it for a short drive about two miles stayed there ok. It may have just worked out/up over time.
