12-07-2020, 09:58 PM | #21 |
Re: Is the MAC's auto parts Model A Ford Engine Stand Adapter necessary?
I noticed he has a couple of Advantage lifts.
TOB |
12-07-2020, 11:38 PM | #22 |
I used the cheap tri leg harbor freight stand and 2 pieces of scrap angle iron. Used 2 of the factory arms bolted to the 2 side water outlet bolts and 2 pieces of scrap angle iron to two of the oil pan bolt holes.
i did make a homemade wood stand to set the engine on its mounting ears to mount the oil pan tho. And ran it on that stand. Now its currently being repurposed as a door caddy haha.
1929 Model AA - Need long splash aprons! Last edited by SeaSlugs; 12-07-2020 at 11:44 PM. |
12-08-2020, 11:10 AM | #23 |
I had one of those "tri-leg" stands and found it very unstable w/an engine on it. I replaced the single caster w/a piece of channel iron w/a caster on each end. Made it very stable.
12-08-2020, 11:42 AM | #24 |
WTSHNN- Nice video link, thanks.
12-08-2020, 12:00 PM | #25 |
Snyder’s quality of service has certainly deteriorated, no longer first choice for me and two close friends.
12-08-2020, 12:33 PM | #26 | |
I see they dont even carry it and did what you did haha: https://www.harborfreight.com/1000-l...and-69886.html
1929 Model AA - Need long splash aprons! |
12-08-2020, 05:00 PM | #27 | |
I bought the HF 2000 lb. Engine Hoist because it looked a lot sturdier than the 1000 lb. Hoist. I am thinking of buying the 1000 lb. engine stand but I notice the tiny wheels in the back. Have they been any problem for you or anyone else that has one? I’ve been thinking of going with the 2000 lb. Stand just to be on the safe side. By the way, are SeaSlugs closely related to Banana Slugs found in the Redwood Forests? David Serrano |
12-08-2020, 05:03 PM | #28 | |
12-09-2020, 08:30 AM | #29 |
12-09-2020, 11:13 AM | #30 | |
12-09-2020, 06:54 PM | #31 |
yes flipping and engine over on these stands is always a bit of a scare. Best to have someone help you. The gearbox would of been very nice to just slowly roll over and it catch itself.
12-09-2020, 09:40 PM | #32 | |
