Old 08-25-2023, 12:49 PM   #1
SteveW
Default 1930 Rear Brake Drum Hub Type/Style
I'm looking for information on these two different styles of Model AA Rear hubs, why the difference ? See attached photos ....
Thanks
Steve
SteveW is offline   Reply With Quote
Old 08-25-2023, 03:30 PM   #2
Bob C
Default Re: 1930 Rear Brake Drum Hub Type/Style
I wonder if the one on the right ws used with the 1931 spoke wheel?
I guess not, the spoke wheel drum looks totally different.
Old 08-25-2023, 04:34 PM   #3
john charlton
john charlton's Avatar
If you check the "Service Bulletins " you will see when the early AA " scalloped " hub on the new bevel gear rear axle was changed . This early hub was causing wheel hub area failure with heavy loading . A stiffening plate was issued in service to prevent failure . Your pictures show both early and late styles .
John in West Drayton London sunshine and showers .
Old 08-26-2023, 12:06 PM   #4
SteveW
Thanks John for the information .......
Regards
Steve
