Old 07-03-2023, 06:37 AM   #1
john charlton
john charlton's Avatar
Default 82 A 28/29 AA Truck cab question
When I bought this truck no body blocks were fitted . I fitted new blocks with the rubber pads tacked on . I was not sure if anything went under the front single bolt mounting so I fitted a rubber pad the same thickness as the others . This raises the front of the cab that the latches do not fit so I have removed them . At the front bolt the block is sandwiched between the steel channel so the connection will be " metal to metal" or is frame webbing involved ?
John in Suffolk County England . Mixed weather today sunshine and showers
Old 07-03-2023, 07:23 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 82 A 28/29 AA Truck cab question
John, there should be a 1/16th thick woven Anti-Squeak pad under the front, and the pad was folded for the rear to a double thickness of 1/8th inch. Rubber was not used originally.
File Type: jpg A-16542 Frame Welt to Splash Apron - Front.jpg (53.5 KB, 32 views)
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-03-2023, 08:00 AM   #3
john charlton
Thank you Brent all is clear .I have suitable material .
John in same place same weather
Old 07-03-2023, 08:06 AM   #4
wrndln
Is this pad only used on CCPU and AA bodies? On my 28 coupe, there is the frame webbing and the splash apron on it only before the body is installed. The front body block encased in the metal on the top and bottom, just sits on the splash apron, i.e. no pad between them. Is this right? I can understand that means there is metal to metal, but the bolt that secures the cowl to the frame is very tight, so squeaking would seem to be a low probability.
Rusty Nelson
Old 07-03-2023, 09:01 AM   #5
BRENT in 10-uh-C
Rusty Nelson
While these are made incorrectly solely out of rubber, look at the long pads for the #1, and #2 & #3 body bolts.
BRENT in 10-uh-C
Old 07-03-2023, 09:18 AM   #6
Neil Wilson
Neil Wilson's Avatar
The body pad shown (as extracted from Brent's photo) was used on the 1928—June-1930 82-A (as well as other 1928/1929 A bodies). The pad fit under the body (not attached to the front body block).
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
