04-09-2021, 09:01 PM | #1 |
8BA oil canister bolts
Hi guys, what size are the mounting bolts that mount the bypass oil canister to the head?
Nomad |
04-10-2021, 11:00 AM | #2 |
Re: 8BA oil canister bolts
The early 8BA filter was attached by head bolts. On later 8BA engines (possibly some late 1949) and 1950 and up the filter was attached directly to the head by three cadmium-plated bolts. They were 3/8"-16, 3/4 inch long. There were also 3/8" lockwashers.
Ken
https://www.nirgv8.org |
04-10-2021, 11:14 AM | #3 |
Are you sure? I thought they were 5/16"; I better go look at my car!
04-10-2021, 11:30 AM | #4 |
Heck, I'm pretty sure you are correct, Tubman. I shouldn't trust the chassis parts catalog.
Ken
04-10-2021, 11:35 AM | #5 |
Yup. 5/16 is the size. If you install heads that don't have the mounting holes for the 5/16 bolts you can use longer bolt studs that will accomodate the base of your redesigned and modified (5/16 " inch ) filter base. However you also then have to modify your oil lines to fit.
04-10-2021, 12:26 PM | #6 |
04-10-2021, 12:45 PM | #7 | |
And the "Eddie Meyer" heads on the 8BA in his '36 3-window have the same provision. DD ...... |
04-10-2021, 12:58 PM | #8 |
[QUOTE=V8COOPMAN;2005737]The new "Edelbrocks" have 'em too, as seen here on "Heard's" new engine for his '35 pick-up! DD
My Offy heads have same provision in same location. Probably the preformed oil lines I got for the filter fit the stock heads as I’ll have to tweet them to fit where the canister mounts on the Offy’s. Thx all for the bolt size info!
Nomad |
04-10-2021, 01:25 PM | #9 |
On my Offy head the 5/16-18 falls in & 3/8-16 just starts 1 thread & binds? Can’t imagine but could it be Metric? Doesn’t make sense as other mounting features like for thermostat housings & other are 5/16-18 & thread easily. Mount holes for oil filter are clean? Puzzled & don’t wanna maniac the threads.
Nomad |
04-10-2021, 01:29 PM | #10 |
Going to hardware store to get Metric size & check
Nomad |
04-10-2021, 01:48 PM | #11 |
Lets us know what you find out. I'd hate to see Offenhauser succumb to this. I bought a set of stainless headers off eBay for a ridiculous price. The headers were fine, but they came with metric bolts.
Coop, I'm not really clear on what you are saying. Both sets of heads have the provision for the mounting bolts, but do they have the correct spacing (pattern)? I have a set of new in the box 25 year old Offenhauser heads. I think I'll check those out of idle curiosity. |
04-10-2021, 02:29 PM | #12 |
Was not metric tried a 10 mm which seemed closest in size. Barely to didn’t even start. Went back to 3/8-16 to 1-1.5 threads hand tightened then w a ratchet went very carefully tightened & was tight but didn’t feel crossed. Interference fit. Maybe they used a dull tap, maybe wanted interference fit. All three were are tight but tightened correctly.
Nomad |
04-10-2021, 02:40 PM | #13 | |
I guess I lacked a whole lot of clarity with MY statements. The pattern on the two examples I posted APPEARS to match the stock pattern that Jim (19Fordy) showed with the Merc head, especially with reference to the two adjacent head-bolt holes. DD |
