Old 11-16-2012, 07:34 PM   #1
oldmanandakid
oldmanandakid's Avatar
Default Bumper Bolts
Are the bumper end bolts pressed in or do I just need a bigger hammer?
oldmanandakid is offline   Reply With Quote
Old 11-16-2012, 07:41 PM   #2
Steve Plucker
Default Re: Bumper Bolts
No, they are not pressed in but a lot of times they seem like they are pressed in.
Be gental with them...don't be trying to pound them out...maybe a little heat and soking in KROIL.
Pluck
Old 11-16-2012, 07:41 PM   #3
Arlen
Arlen's Avatar
If the nut if off the bottom end, need a bigger hammer
DMAFC
Arlen is offline   Reply With Quote
Old 11-16-2012, 08:56 PM   #4
montanajohn
I had that problem on an extra set of '30 bumpers. End bolts would not budge after soaking with penetrating oil, beating with a 3-lb sledge, and invention some new combinations of bad words. I resorted to my 20-ton HF hydraulic press. It worked. They were just rusted in. I could hardly believe it. Good luck. You will eventually win.
montanajohn is offline   Reply With Quote
Old 11-16-2012, 09:19 PM   #5
mot
Registered User
mot's Avatar
i found that cutting the bolt between the bars makes it a whole lot easier to remove them
sometimes its only stuck on one bar,if its stuck on two bars ,its almost impossible to remove
tom
mot is offline   Reply With Quote
Old 11-16-2012, 09:57 PM   #6
Kevin in NJ
They can be a problem.
I found you can get some of the rust out with electrolytic rust removal. I had one bolt that got loose by letting it set for a few days in ERR. Then I worked on it with a hammer some and eventually it came out. The other end got loose cause I could twist the bumper on the bolt.
Part of my goal was to get the spacers intact.
Since then I had done some front spring perches with a long throw air hammer. I would try that on the bumper bolts, but it is critical that you have a very solid hold on the bumper.
Penetrating oil does not work. Heat will ruin the spring steel bumpers.
I believe good luck is the best hope.
Kevin in NJ is offline   Reply With Quote
Old 11-16-2012, 10:18 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I've worked on a couple front bars where I had to cut the bolt on one end, then I could swing the bars around to loosen the other end. Next time I will try my port-a-power with the spreader attachment to pop off one bar.
Old 11-16-2012, 11:03 PM   #8
oldmanandakid
Thanks Guys. Good advice and good humor. I'll go at it again tomorrow with a smile and a couple of more options.
Old 11-20-2012, 08:01 PM   #9
oldmanandakid
OK Guys here is how I did it. One end the front bumper was soaked in evaporust and one end of each of the rear bumpers was soaked in vinegar for about a day and a half. I then put a pipe wrench on the spacers and turned them, followed by lots of cheap penetrating oil. Then I drilled a hole in the end of the bumper bolts just large enough to accept the end of my HF air hammer pointed chisel. Before starting the hammer I took a small pick and removed all of the debris between the bolts and bumper that I could easily reach. Then I applied the air hammer and in a bit the bolts began to back out. I then tried it on the bumper ends which had not been soaked and the dry ends came out much easier than those which been soaked.
All of this was after my 12 ton press failed to do the job and I melted down three hammers and wore out two anvils trying to beat those things out.
