09-10-2013, 07:35 AM | #1 |
How much toe?
I'm at the garage and they have no specs, what's the best toe setting for my '39?
Gene |
09-10-2013, 07:59 AM | #2 |
Re: How much toe?
The manual says correct toe-in is 1/16 inch
09-10-2013, 08:02 AM | #3 |
Re: How much toe?
Thanks, that's what I thought
Gene |
09-10-2013, 08:14 AM | #4 |
Re: How much toe?
Gene, I have found that placing the toe at about 1/8 makes the car steer much easier. Yes, the tires will wear a tad quicker but realistically, they will still last nearly as many miles as if the tow was set to 1/16".
09-10-2013, 10:15 AM | #5 |
Re: How much toe?
By the time I got this post it was done. It drives great with 1/16". I'm very pleased. Thanks guys!
Gene |
09-10-2013, 01:53 PM | #6 |
Re: How much toe?
09-10-2013, 04:30 PM | #7 |
Re: How much toe?
When I did mine,I clamped a straight solid piece of metal stock to the face of the drum.I kept it level with the floor.The metal was long enough to extend past the front of the frame in the front and slightly longer then the face of the drum in the rear to aid in measuring.Take a measurement at the back of the metal and then measure the front.Adjust as necessary to maintain1/16 to 1/8 less distance at the front.Crude but it worked fine for me.I took it to the garage where I work and checked it with the alignment equipment and it was spot on.Others may chime in with a better way
Bill |
09-10-2013, 07:52 PM | #8 | |
Re: How much toe?
When Craig Breedlove built the First "Spirit of America" land speed reord holder in his parents garage he did much the same thing. Good old Yankee ingenuity... Torchie. |
09-10-2013, 08:23 PM | #9 |
Re: How much toe?
Breedlove's Spirit of America had zero toe. When built and for all runs thereafter it was a three wheeled vehicle.
09-11-2013, 01:41 AM | #10 |
Re: How much toe?
Jackstands on the shackles to maintain the unsprung relationship.
Tires spun holding chalk at the center of the tread. Pencil line on the chalk. Measurements taken at the front and rear, halfway up the tires. 1/16" to 1/8" difference is the correct measurement. A measuring jig can be made with a 2x4 stud having right angle upright pointers. Fasten a 6" scale horizontally at the top of one pointer.
Alan |
