Old 08-04-2021, 10:17 AM   #1
Tom in SW VA
Tom in SW VA's Avatar
Default Steering Sector grease or oil for 37 Ford??
What grease or oil do you use or recommend for the steering sector box on my 37 Ford?
Your help is appreciated.
What about Champion OO?
Tom in SW VA is offline   Reply With Quote
Old 08-04-2021, 10:44 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Steering Sector grease or oil for 37 Ford??
Normally, they use SAE-90 gear oil but some folks use John Deere Corn Head thixotropic grease due to excessive seal leakage.
Old 08-04-2021, 11:07 AM   #3
David J
David J's Avatar
33-34's here and I use SAE 140 .
Actually use it it trans , rear , u-joint and steering .
GL4
David J is offline   Reply With Quote
Old 08-04-2021, 12:11 PM   #4
Terry,OH
Terry,OH's Avatar
The top of the cap says EP (extreme pressure) which leaves the corn head grease out. I use the same lube as the transmission and rear differential SAE 140W
Old 08-04-2021, 01:29 PM   #5
1931 flamingo
1931 flamingo's Avatar
Penn Rite steering box lube............................NO leaks.
Paul in CT There is something similar available at Tractor Supply.
Old 08-04-2021, 02:26 PM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
I've used John Deere Corn Head Grease since 2013 in my '35 fordor sedan. In early 2013 I was prepping my car for a cross-country trip and intending to completely redo my brakes, rebuild the rear while installing 3.54 gears, and rebuild the steering gear as necessary, and prevent the box from leaking gear oil. As our departure time, first week in June, got closer and closer, I decided not to tackle the steering and try the JDCH Grease to provide good lubrication and hopefully stop, or at least decrease the leakage problem as many people had recommended it would.....and they were correct. After traveling 7,200 miles on this trip, I only lost a slight amount of the JD grease and confirmed an improvement in ease of steering. Eight years later, I'm still using JD grease in the steering box, and only adding a slight amount every other oil change.
Now truth be told....if or when I rebuild that steering box, and confirm I've corrected the leaking problem, I would use the Penn Rite steering box oil, as others here have recommended.
John
Old 08-04-2021, 08:14 PM   #7
Tom in SW VA
dtd
Old 08-04-2021, 09:30 PM   #8
John R
John,
If you've had such good luck with the Corn Head grease, why change to the Penn Rite?
John
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 08-05-2021, 08:19 PM   #9
paul2748
paul2748's Avatar
I haven't used it myself, but there have been some recommendations for Super S 00 grease from Tractor Supply
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-06-2021, 07:38 AM   #10
JM 35 Sedan
Originally Posted by John R View Post
John,
John
John, as I mentioned, "if" I ever do rebuild this steering box, my main goal would be eliminating the leaking issues. To determine that, I would start out by filling the box with oil. Based on what I've heard and read about the Penn Rite oil, it sounds to me like this would be an excellent choice to start with.
John
Old 08-06-2021, 08:08 AM   #11
richard crow
the trouble with grease is it doe,s not flow in cold weather. we call it tunneling fix the leak it,s ez & fill it with 90 weight like ford says. you lucky guys that live in a warm place it don,t matter
richard crow is offline   Reply With Quote
Old 08-06-2021, 08:24 AM   #12
51504bat
51504bat's Avatar
Corn head in my '39 p/u's box.
Old 08-09-2021, 04:17 PM   #13
alchemy
alchemy's Avatar
How many of you drive your car when it's under 40 degrees? And even if you do, it will only take a few minutes for the exhaust to warm up the steering box right next to it.
Corn head grease should be fine for everyone except that die-hard in Alaska.
I have it in the F-1 box in my 32 sedan and think it's great. The F-1 boxes have the same internals as 37 to 48 passenger cars, so it should work just fine in the OP's 37 too.
alchemy is offline   Reply With Quote
Old 08-09-2021, 04:35 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Oh, the joy of listening to a Man of Reason! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-09-2021, 04:59 PM   #15
JM 35 Sedan
Richard, I'd agree with you on using a hi temp grease in the steering box, but JD Corn Head Grease is not hi temp and flows well for it's intended use. There is a video on JD's website that tells the story on how this works in their farm equipment, and it also works quite well in steering boxes, and the early Ford enclosed type universal joint.
John
Old 08-13-2021, 06:18 PM   #16
alumcantandthd
It's "Cotton Picker 00 Spindle Grease"
alumcantandthd is offline   Reply With Quote
Old 08-14-2021, 03:08 PM   #17
highbeams
highbeams's Avatar
Are instructions available regarding installation of an F-1 box?
My '36 p'up was close to impossible to parallel park. Two-arm pull per each 'turn' - the truck would rock with each pull. Absolutely unacceptable. Didn't the public object to FoMoCo?
(and I once read that Chev GM was worse)
Is there info regarding why the box was engineered in such a cheap 'Who Cares?' way?
Edsel & Gene Gregorie actually 'passed' this piece of 'scrap-iron'?
How would the fairer sex fare parking when shopping?
At least provide a FoMoCo logo crowbar w/each car . . . one end on passenger floor, the other through the steering wheel spokes - PULL! PULL! PULL!
highbeams is offline   Reply With Quote
Old 08-14-2021, 03:42 PM   #18
FlatheadTed
FlatheadTed's Avatar
Tyre's were narrow and roads were gravel , to set up a steering box can be a real challenge ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
