Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 12-21-2019, 04:11 PM   #1
blackcoupe
Default Removing lock cylinder from 34 Ford trunk handle
Can lock cylinder be removed from trunk handle without a key? If so, what is the trick as I am having no luck. Thanks, Jerry
blackcoupe is offline   Reply With Quote
Old 12-21-2019, 06:51 PM   #2
Charlie Stephens
Default Re: Removing lock cylinder from 34 Ford trunk handle
Welcome. You posted in a forum intended for questions to the editors about the site. It is seldom read or responded to. Leave it here but also post here:
https://www.fordbarn.com/forum/forumdisplay.php?f=4
Best of luck.
Charlie Stephens
Old 12-21-2019, 08:52 PM   #3
blackcoupe
Thanks Charlie did as suggested.
