05-26-2020, 09:26 AM | #1 |
should it be of "concern"?? What do the experts say
On my "Stock" flathead," Most " of the time when I have been driving it, the temperature, as it comes up to operating temp, goes all the way to "H" and will stay there approximately 30 seconds to maybe a minute, then drop to the mark between "N" and "H" and pretty much stay right there (and a few times it never makes "H" before it drops back to normal), maybe creep up to between the middle notch and "H" "occasionally" at a long stop or light, should I be concerned with that???? Yesterday when I drove it, it did just as I described BUT once I got it out on the road running it stayed below the center mark the whole time, 76 degree's and overcast here yesterday!!!
05-26-2020, 09:30 AM | #2 |
Re: should it be of "concern"?? What do the experts say
I'd start with a known good mechanical or electric gauge so you know exactly what temps are not just H or N. Once you have exact numbers you can investigate further if necessary.
05-26-2020, 09:45 AM | #3 |
The rising and falling is probably the thermostat opening and closing. Like 51504bat said you cant really know what temps it is running at without checking it with a good gauge. Also check the thermostats to make sure they are working correctly.
05-26-2020, 10:27 AM | #4 |
What would I do?
Tape over the gauge so I could not see it. If at any time it boiled over, then I would be "concerned"
05-26-2020, 10:33 AM | #5 | |
That has been what I have been thinking as it doesn't puke any coolant or loose any and it always drops to a "comfortable" level so I figure the the thermostats ARE working as within a minute it drops SO......AND its runs out beautifully thanks to Hoop & CharlieNY. |
05-26-2020, 10:53 AM | #6 |
05-26-2020, 11:31 AM | #7 |
Go on line and order an infrared thermometer, Lowe's even sells them $39.00. You know you need more tools anyways.
05-26-2020, 11:33 AM | #8 |
The temperature sender is down in the head. The thermostat bi-metal coils that open the thremostat are up in the neck. It has to get to H in the head before the temp in the neck gets up enough to open the thermostats and start the coolant flow.
I drill two 3/16 holes in the flat edges of the thermostats. That allows some water to flow by the bi-metal strips when the thermostat is closed. That will slow your warm-up a tiny bit, but you will cure that initial swing to H. That behavior is of no real consequence, but I just hated seeing that thing go to Hot every time. It causes unpleasant remembrances of sitting at the side of the road with boiling flatheads. |
05-26-2020, 11:40 AM | #9 | |
