Old 11-04-2015, 11:16 AM   #1
Gufshoz
Gufshoz's Avatar
Default Self inflicted electrical woes.
I have a 1930 coupe that has had the wiring for the lights, horn, and add-on bumper mounted turn signals ran through the firewall. This modification was done in the 60's to avoid having to replace the light and horn rod. The car was a daily driver for my high school days in the late 60's and ran reasonably well until I somehow screwed things up. Recently, I had to repair the radiator, so I ran new wiring to the headlights, installed a new ignition switch, ammeter and wiring harness for the switch and ammeter. Since that time the car only runs off the charged battery. I had the alternator and the battery checked and they're both in great condition. What should I be looking for next? I know that there must be a short somewhere, but I've traced all the wiring and can't find it. Any suggestions are greatly appreciated.
Gufshoz is offline   Reply With Quote
Old 11-04-2015, 11:45 AM   #2
Gufshoz
Gufshoz's Avatar
Default Re: Self inflicted electrical woes.
PS Clarification: All electrical systems operate. The battery holds its charge except when the motor is running.
Thanks
Old 11-04-2015, 12:06 PM   #3
Charlie Stephens
What does the ammeter say when the motor is not running and you turn on the head lights? It should say about -10 amps for stock lights and more for sealed beams. You said you had the alternator checked, what does the voltage read when the car is running?
Charlie Stephens
Old 11-04-2015, 12:25 PM   #4
burner31
burner31's Avatar
Have you checked your cutout wiring?
Check/clean all grounds?
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-04-2015, 12:29 PM   #5
Charlie Stephens
Do alternators have cutouts? I must have missed something.
Charlie Stephens
Old 11-04-2015, 12:53 PM   #6
burner31
burner31's Avatar
Missed that "alternator" part...Opps
But checking all the grounds still stands.
Keith
Shawnee OK
'31 SW 160-B
Old 11-04-2015, 02:57 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Check the alternator output stud for voltage with the engine off, then with the engine running. Be sure to kick up the speed so the alternator kicks in. You should go from about 6.3 volts with the engine off, to about 7 volts with the engine running.
If the voltage doesn't increase when running, then the alternator is bad. If it increases, then check both terminal box wing nuts for the same 7+ volts, then move down to the starter switch stud and check it for 7+ volts.
Let us know what each of these readings are.
Old 11-04-2015, 03:43 PM   #8
Gufshoz
Gufshoz's Avatar
Ta-da,
Fixed. At least the first 5 mile test drive was ok. Did I mention that I had to replace most of the wiring because the first time I got it running, after putting the repaired radiator back, it caught on fire. Melted most of the terminal box wires. I couldn't understand how the motor could run if the wiring wasn't right. I just removed all the wires from the terminal box and reconnected them (today). I had the yellow wire from the starter connected to the wrong terminal. I had been using a composite of several different wiring diagrams. I hope that it's true that we learn more from our mistakes.
Old 11-04-2015, 06:50 PM   #9
Jwilli
Jwilli's Avatar
We do learn from our mistakes. It takes a real man to admit that he made a mistake. Enjoy your car.
Jwilli is offline   Reply With Quote
Old 11-05-2015, 12:18 AM   #10
Flathead
Flathead's Avatar
Anybody who can say they never ever made a mistake is either lying or has never done anything. We all make mistakes from time to time.
Flathead is offline   Reply With Quote
