Old 04-19-2018, 11:39 AM   #1
marko39
Default fuel pump pushrod bushing replacement
i am rebuilding a 8ba and was wondering the best way to replace the fuel pump pushrod bushing or is this something that is not normally done. the block is stripped and clean and i do have play in the bushing using a new pushrod. how much is hard to tell but i can move pushrod on top about 1/8 inch back and forth. do new bushings need to be reamed?
marko39 is offline   Reply With Quote
Old 04-19-2018, 11:51 AM   #2
JWL
Default Re: fuel pump pushrod bushing replacement
That bushing almost never needs replaced and is not a tight fit at the rod when new. Your example sounds good to go.
JWL is offline   Reply With Quote
Old 04-19-2018, 02:00 PM   #3
marko39
Thanks, i was hoping that was the case, it looks as though it could be a bitch to replace.
Old 04-19-2018, 03:01 PM   #4
leon bee
I wondered about this as well, hoped I wasn't cutting corners by leaving it. There are so many books and sites around regarding flathead rebuilds- I have read a couple that say you gotta replace it.
Whenever I can cut down on buying expensive parts I'll buy JWL's book.
leon bee is offline   Reply With Quote
Old 04-19-2018, 04:14 PM   #5
JSeery
JSeery's Avatar
It is a hardened bushing and not likely to be worn out by the pushrod. Also it is not easy to replace! JWL's book should be one of the first items on your list, might save on some of the expensive parts!
Old 04-19-2018, 05:29 PM   #6
19Fordy
19Fordy's Avatar
marko, From what you describe, I would say, let it be.
Old 04-19-2018, 05:49 PM   #7
Andy
I believe the bushing obstructs the ability to rod out the oil passage. They can be driven down into the bearing bore. The same mandrill can be used to reinstall. That is what I did.
Andy is online now   Reply With Quote
Old 04-20-2018, 04:26 AM   #8
big job
big job's Avatar
I just did that, my opinion, I don't like wiggles, not about to cheap out on a 2 dollar
bushing and a new pump rod. As Andy said drive it down into the cam bore. Now
I have absoultly no wiggle and the rod slowly slides down under its own weight. I bought
this bushing right down the street (engine builder) . Never seen this type; the inside
bore has three ribs to retain oil. I didn't ask but I think they machined this bushing.
They have a box of these on the shelf Yes they are well versed on 32-53 V8's. They
thermo cleaned my block & magnafluxed it--What a job looks brand new.
big job is offline   Reply With Quote
Old 04-21-2018, 07:41 AM   #9
marko39
what did you use for a mandrill? after taking measurments it appears i have about .010 clearance in bushing. checked another pushrod and it is .005 larger than the one that was marked nos.
Old 04-21-2018, 08:59 AM   #10
Ol' Ron
Ol' Ron's Avatar
On many of my builds I remove the bushing and plug the hole with a pipe bushing, eliminating the fuel pump push rod. That is when we rotate the rear cam bearing to plug the bottom hole. This is used in some racing applications.
Old 09-07-2023, 12:21 PM   #11
jake197000
i change them so i can clean out oil galley.they go in kind of hard
jake197000 is offline   Reply With Quote
