Old 03-01-2021, 08:02 PM   #1
Talkwrench
Talkwrench's Avatar
Default Water is not supposed to be there...
Well Its not often I get let down but it wouldn't start at work ..clunk was all I got. Eventually it started and I drove home and knew something was not right it was running on 6 -7 cylinders, vacuum gauge was down and fluctuating.. After pulling heads this is what I found looks like a crack in no.8 . I built and have been running this engine for about three and a half years..
Old 03-01-2021, 08:06 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Water is not supposed to be there...
Old 03-01-2021, 08:46 PM   #3
Will D
Will D's Avatar
That's not the end to the day anyone wants. Is it repairable? Can it be sleeved?
Hoping for a speedy recovery, if its possible.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 03-01-2021, 08:50 PM   #4
JSeery
JSeery's Avatar
That's not good!
Old 03-01-2021, 09:15 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
Yep - that would do it! Has had water in the cylinder for awhile - can see the rust pitting.
My guess is that you should be able to sleeve that one hole, put new rings on the piston and be good to go. Given that you had a starter "clunk", then you most likely had a lot of water in the cylinder and hydrauliced (sp?) the engine. I would have the rod for that cylinder checked for straightness and check the rod bearings.
Old 03-01-2021, 09:48 PM   #6
Talkwrench
Talkwrench's Avatar
Correct, and yes Brian already said check the rod because of Hydro
Old 03-01-2021, 10:14 PM   #7
51 MERC-CT
51 MERC-CT's Avatar
Might be dirt or something but it sure looks like a burnt exhaust valve in #5 cylinder.
And to me the overall condition doesn't look that great ether.
Old 03-01-2021, 10:36 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
looks like the head gasket has problem at the rear water passage, the black areas usually are suspect places for leaks on that type of gasket
where is the suspected crack? ---is it the lower stud? ---how large is the bore>
I don't think it is a crack most likely if it was cracked it would go all the way to the deck and over to the hole
Old 03-01-2021, 10:54 PM   #9
petehoovie
petehoovie's Avatar
Hydrolock
Old 03-01-2021, 11:14 PM   #10
Talkwrench
Talkwrench's Avatar
Personally I thought it would look better when I opened it up. I think the valve is fine . Used to get 21 -22 Hg at idle [with twin carbs] I could pull 60mph out of second easy., was a great engine but did spend most of its time in commuting.
Old 03-01-2021, 11:20 PM   #11
Talkwrench
Talkwrench's Avatar
Yes it does look as tough he gasket has be leaking. yes lower stud, its only .030 over. Its really hard too see its why I took the stud out ..Im still convinced its a crack
Old 03-02-2021, 06:36 PM   #12
Bored&Stroked
Looks like a crack to me. You'll need to pull the motor down to sleeve it anyway, so I'd do a pressure test on the block - you'll then know for sure where the crack(s) are.
Old 03-02-2021, 07:09 PM   #13
mfirth
That is sad.....
mfirth is offline   Reply With Quote
Old 03-03-2021, 12:50 PM   #14
Kurt in NJ
Kurt in NJ's Avatar
do you have a armature growler? it can be used to magnaflux, and i used to use .001-.002 cuts on rotor lathe to make 'powder"
is it a blind stud hole?
Old 03-03-2021, 03:08 PM   #15
jetmek
A weak spot on 21 stud engines. Had one let go on a fresh rebuild. It distorted the top of the cylinder bad enough to lock up the engine.
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 03-03-2021, 04:17 PM   #16
Lawrie
Lawrie's Avatar
Rob , price some freight, I have a complete 24 stud 221 engine you could have.
and I second the look at the gasket, I had one just like it on the 33 the other month, the black areas specially.
Lawrie
Old 03-03-2021, 07:15 PM   #17
Talkwrench
Talkwrench's Avatar
If it comes down to it Lawrie I will do thank you.
I need to take it out and assess it further , Ive been dawdling on the other [backup] engine so now I have to get the skates on and finish it so I can swap over , I still have not found 3 1/16 + .100 rings
Keith dropped off a sleeve the other day so it could come in handy.
Old 03-04-2021, 02:10 AM   #18
Lawrie
Lawrie's Avatar
get onto Hastings or grant for the rings.
Lawrie
Old 03-04-2021, 05:11 PM   #19
Lawrie
Lawrie's Avatar
Rob, I have some new model A engines coming over from Perth freight cost is very good, maybe not there other way.
And get a crack tester kit from Blackwoods and check it, but I think it will be the gasket.
Lawrie
Old 03-05-2021, 09:17 AM   #20
deuce5wndw
deuce5wndw's Avatar
So the head gasket leaked into the cylinder and hydro locked causing the cylinder to crack correct? Had that happen once on a 428CJ.
deuce5wndw is offline   Reply With Quote
