Old 07-01-2017, 05:13 PM   #1
30Ford
Default Generator Problems
Well i checked the voltage on my generator today ...on the load side of the cutout I had battery voltage ...on the generator side with the engine reved up I got 1.2 volts .....I motored the gen and it turned in the direction of the motor ...I had .2 of an ohm between the case of the gen and the Positive post ... I installed a ground wire to the motor to make sure it was grounded..... The field coil drew about 5 amps and put the armature on the growler ..all seemed good ...put the gen on a test bench and it ran 7.2 volts ...now nothing any Ideas before I tear it apart
Thanks
30Ford is offline   Reply With Quote
Old 07-01-2017, 05:51 PM   #2
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Re: Generator Problems
Measure the output ahead of the cut out. Get the cutout out of the picture.
Jacksonlll is offline   Reply With Quote
Old 07-01-2017, 06:41 PM   #3
CWPASADENA
CWPASADENA's Avatar
With the engine running at about 1000 RPM, momentarily jumper across the cut out and see if the generator then is charging.
If so, change the cut out.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 07-01-2017, 06:50 PM   #4
Ed H.
Ground the fields, this will give you full gen output.
If you see a bomb technician running, do everything in your power to keep up with him.
United States Navy
Ed H. is offline   Reply With Quote
Old 07-01-2017, 06:55 PM   #5
30Ford
From the gen out put terminal to ground @ 1000 rpm it is 1.2v
Old 07-01-2017, 07:38 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
If it had 7.2 on the bench test, then it should have the same on the car. I was going to suggest a poor ground at the mounting bolt, but you said you used a jumper wire to ground. Just be sure the clips on the jumper wire are soldered to the wire at each end. I had an alligator clip once with a bad connection because the metal was folded over the wire insulation, and the wire didn't touch the clip.
Old 07-01-2017, 10:03 PM   #7
30Ford
Tom I put a #2 cable from where the positive is bolted to the frame and the other end bolted to the bellhousing and have .2 of a ohm from the positive terminal to the case on the generator case...I'am thinking a wire fell down on the armature
