Old 08-05-2022, 04:25 PM   #1
Ian NZ
Ian NZ's Avatar
Default 1932 Ford Radio
Would anybody know how to remove the key from a 1932 Ford Grisby & Grunow radio header control on the steering column I cannot remove the one off my control at all.
Ian NZ is offline   Reply With Quote
Old 08-05-2022, 06:43 PM   #2
koates
Default Re: 1932 Ford Radio
Ian, If it is the type shown in you drawing it should pull straight out. You might have to give it a hard tug and it should come completely clear. All it does is open or close a set of electrical contacts in the power circuit. Regards, Kevin.
koates is offline   Reply With Quote
Old 08-05-2022, 10:51 PM   #3
Ian NZ
Ian NZ's Avatar
I have tried tugging it but it wont move , I might have to make or put a puller on it I do not want to wreck anything inside the chamber.
Old 08-07-2022, 02:34 AM   #4
Ian NZ
Ian NZ's Avatar
I have talked to other owners of this radio and they are having problems with the contacts on the Header control too.
Old 08-07-2022, 08:30 AM   #5
Terry,OH
Terry,OH's Avatar
From your photo rotating while pulling may help if not try some penetrating lube
Old 08-08-2022, 04:47 PM   #6
Krylon32
Don't panic, David G will probably chime in?
Krylon32 is offline   Reply With Quote
Old 08-08-2022, 05:54 PM   #7
DavidG
DavidG's Avatar
Ian already asked me via email. The radio key should be removable with only a little bit of resistance, but in fairness it was more than forty years ago since I last had a '32 radio. The '33 Grigsby-Grunow glove box radio also had a similar key. For sure, those keys are removable without the use of tools, however 90 years of oxidation could be a very effective glue.
Old 08-08-2022, 06:38 PM   #8
Anteek29
Anteek29's Avatar
I'd try lock dry lube - comes in an aerosol can. Stuff is great and will not leave a residue.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 08-09-2022, 05:13 PM   #9
Ian NZ
Ian NZ's Avatar
I have contacted two other owners of 1932 cars fitted with radio and they cannot remove the key.
I have dismantled the header control by breaking the knob and have found that it does not have a removable key so it seems that the later models do not have a removable key.
Now too making up parts.
Thread Tools
Display Modes
