Old 06-30-2022, 09:32 PM   #1
metro1
Default Body to frame bushings
I have checked all over the internet for body to frame bushings for my '59 Galaxie with no luck. I was told by a rep. from Dennis Carpenter that a '59 is a one of a kind and they don't have them. Same thing everywhere. Anyone have any suggestions on where I can find them? It seems everyone skips 1959.
metro1 is offline   Reply With Quote
Old 06-30-2022, 09:45 PM   #2
fordor41
fordor41's Avatar
Default Re: Body to frame bushings
I believe '60 basically is the same frame. maybe '61 also. try one of those yrs.
fordor41 is offline   Reply With Quote
Old 07-01-2022, 04:20 AM   #3
KULTULZ
KULTULZ's Avatar
Arrow Re: Body to frame bushings
This vendor advertises 1957-1959 KIT -
https://www.fabulousfords.com/detail...and_Convt.html
Give them a call and report back what you find out.
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 07-01-2022, 07:50 AM   #4
metro1
If the picture is what you get that will not work. I need 10 of the big round bushings and 4 of the flat ones. I did notice they said there were exceptions as to what they would fit. I will still call them and find out.
Old 07-01-2022, 08:58 AM   #5
metro1
I talked with Fabulous Fords and what you see in the picture is what you get which is not what I need . They are out of stock anyway.
Old 07-01-2022, 04:32 PM   #6
KULTULZ
KULTULZ's Avatar
Post Re: Body to frame bushings
FALSE ADVERTISING - COMMON TODAY WITH THESE VENDORS ALONG WITH PUSHING OFF-SHORE JUNK -
- USELESS AS T!TS ON A WART HOG -
The insulators are the same from 1957 (partial) until 1962 on FORD-MERC-EDSEL (exc for CONV - RHT and number used on SEDAN and/or WAGON.
PN's are B8A 6400154-A (upper) and 55-A (lower).
This vendor shows them as a kit . Get back ...
https://www.lincolnoldparts.com/moun...body-2501.html
You may be able to match OEM to polyurethane ...
https://www.suspension.com/universal-isolators.asp
- WHY IS IT ... -
Old 07-01-2022, 07:12 PM   #7
metro1
Thanks for the info. I see the Lincoln old parts store is currently sold out. I'll check with them to see when more are available.
Old 07-01-2022, 11:14 PM   #8
55blacktie
Unless polyurethane bushings contain graphite, they might squeak; use silicone grease.
55blacktie is offline   Reply With Quote
Old 07-02-2022, 10:37 AM   #9
KULTULZ
KULTULZ's Avatar
TRY THIS -
- https://www.dennis-carpenter.com/cars/body/frame/
His kit reads 57/58 but the 59 takes the same insulators. His also comes with the hardware.
- WHY IS IT ... -
Old 07-02-2022, 01:21 PM   #10
metro1
I talked with a rep. there and was told this kit would not work that '59 was different but they do look like what I have. Are the sizes the same?
Old 07-02-2022, 05:59 PM   #11
KULTULZ
KULTULZ's Avatar
The ORIGINAL FORD PART NUMBERS are the same for 1958 to 1962 FORD (1957 partial). I gave the insulator parts list chart above.
It may be that some of the hardware is different but that can be corrected.
I have found three vendors that sell this same exact kit but all give a different song and dance.
The question is who actually makes it and describes it correctly.
Do you have a 1959 FORD SHOP MANUAL? It should give you a detailed ILL showing frame mounting points and hardware. 1957 does.
I don't know. Most of these vendors leave much to be desired (IMO). I would ask what the RETURN POLICY is and order and see what they are. DENNIS CARPENTER has a deal with FORD MOTOR where they acquire the original tooling to repro some of their parts. Whether this kit is FORD APPROVED is up in the air as the ad does not show FORD APPROVED.
- WHY IS IT ... -
Old 07-03-2022, 08:09 AM   #12
metro1
Thanks for all the research you've done. You have been very helpful.
Old 07-03-2022, 09:45 AM   #13
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Body to frame bushings
You are more than welcome.
Some of these so-called vendors are not to speed.
- WHY IS IT ... -
