Old 06-15-2021, 09:44 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Gas Tank Cutaway Photos
I have some photos by Brent Terry of cutaway gas tanks. Are there any others available for posting here. I am building a presentation for my Model "A" club about gas tanks and I need more photos of cutaway tanks.
Bob Bidonde
Old 06-15-2021, 10:15 AM   #2
Bob from Northport
Bob from Northport's Avatar
Default Re: Gas Tank Cutaway Photos
I have about 10 from one tank Brent did for my shop
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 06-15-2021, 10:22 AM   #3
Bob from Northport
Two more
Bob from Northport
Northport, Michigan
Old 06-15-2021, 10:23 AM   #4
Garwood
Garwood's Avatar
That's pretty cool. I'll assume the baffles are to keep the gas from splashing around.
Garwood is offline   Reply With Quote
Old 06-15-2021, 10:25 AM   #5
Garwood
Garwood's Avatar
Is the tank top screwed, bolted or weld on?
Old 06-15-2021, 10:36 AM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bob, tell me specifically what pictures you want and I can probably send you some.
The two halves were welded while submerged originally. We cut them thru the center of the factory weld.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-15-2021, 10:43 AM   #7
bruceincam
bruceincam's Avatar
Originally Posted by Bob from Northport View Post
Two more
I assume that the side to side baffles are "added on" by somebody other than Ford??
bruceincam is offline   Reply With Quote
Old 06-15-2021, 11:18 AM   #8
DBrer
Thanks for the photos, I wondered what the inside of the tank looked like.
DBrer is offline   Reply With Quote
Old 06-15-2021, 11:19 AM   #9
Anteek29
Anteek29's Avatar
Always wondered how those looked inside.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 06-15-2021, 04:43 PM   #10
Papa's CCPU
Papa's CCPU's Avatar
Factory
You can see them in the picture on page 4 here in Steve Plucker's doc...
http://www.plucks329s.org/pdf/gastan...production.pdf
Papa's CCPU is offline   Reply With Quote
Old 06-15-2021, 05:38 PM   #11
Bob from Northport
The side to side baffles are original, not added on by someone. How else would the weight of the gas pushing aside to side in a car not effect steering and performance??
10 gallons of gas would weigh 80 lbs or more. A lot of weight for an unrestricted tank
Bob from Northport
Northport, Michigan
Old 06-15-2021, 05:59 PM   #12
Jeff/Illinois
Jeff/Illinois's Avatar
The newest edition of the Model A News magazine, shows a guy's gas tank that had had some kind of crap sprayed or sloshed around on the inside, probably in the 70's or early 80's before Ethanol, to coat the tank, the junk came loose, and it was blocking the fuel outlet in the tank.
Looked like Granny's undies piled on the car's seat after he took it out of the gas tank. When you see the stuff you say to yourself 'What the ----------?'
Old 06-15-2021, 08:03 PM   #13
bruceincam
bruceincam's Avatar
I guess I need to clarify ---- I'm not talking about the baffles that run front to back in the tank and, therefore, prevent side to side sloshing of fuel. See post number 3 ----- there appear to be baffles in that pic that run side to side in the tank and would prevent front to back sloshing of the fuel. I've only seen those baffles in that pic. Were those baffles that run left to right in the tank original by Ford?
Old 06-15-2021, 08:44 PM   #14
bobbader
Bob,
I have at least 1 30/31 tank with the top cut off at my shop. If you want to photograph it feel free to come over. OR, if you want to, you can take it home and do what you want at your leisure.
Bob Bader
bobbader is offline   Reply With Quote
Old 06-15-2021, 09:00 PM   #15
shew01
shew01's Avatar
If I recall correctly, the front to back baffles were added for 1930/1931. 1928/1929 only had side to side baffles. Brent Terry posted some really interesting gas tank pictures a couple of months back.
Old 06-15-2021, 09:02 PM   #16
shew01
shew01's Avatar
See Gas tank cleaning
https://r.tapatalk.com/shareLink/top...ink_source=app
Gas tank cleaning question
Old 06-15-2021, 10:32 PM   #17
bruceincam
bruceincam's Avatar
Thanks ----- looks like all the baffles were original Ford at one time or another.
Old 06-16-2021, 01:51 AM   #18
mercman from oz
mercman from oz's Avatar
Very interesting photos of the inside of a Model A Fuel Tank.
Old 06-16-2021, 07:12 AM   #19
Bob Bidonde
Brent,
I need pictures of the interior yank at the locations of the steering support and the shutoff valve in 1928-'29 and in 1930-'31 tanks. Thank you Brent and all of the others who contributed to this post.
Bob Bader,
I would like to borrow your cutaway tank as a show & tell piece for the clinic on July 10th. I will stop over as soon as I can drive again (cataract surgery today). Thanks for your offer. Stay well my good friend.
Bob Bidonde
Old 06-16-2021, 11:50 AM   #20
katy
katy's Avatar
What is the filter(?) on the floor in the middle picture?
