Old 02-07-2018, 05:57 PM   #1
d210000439
Default 1933 Cabriolet pivot bolts
Looking for the shoulder bolts and nuts that attach the nickel plated bar that connects the convertible top to the door pillar.
The bolt is at the door pillar and attaches the bar to an elongated slot.
I believe the part numbers are:
Bolt: 40-764864
Nut: 40-764862
If you know where I can get a pair or an accurate sketch or drawing with the dimensions I'd really appreciate it.
Thanks!
Don
d210000439 is offline   Reply With Quote
Old 02-07-2018, 07:04 PM   #2
Keystone 34 3w
Keystone 34 3w's Avatar
Default Re: 1933 Cabriolet pivot bolts
3/8"-24 thread.
Keystone 34 3w is offline   Reply With Quote
Old 02-07-2018, 07:12 PM   #3
Keystone 34 3w
The nut is also serrated on the back face to grip to the pillar.
Old 02-07-2018, 10:25 PM   #4
d210000439
Thanks, that's helpful if I have to have one made.
Any thoughts on someone who has a pair?
Old 02-08-2018, 12:46 AM   #5
Graham Freeman
Do you have the original top pivot bolts for the steel header.
I need a pattern for a pair or someone to accurately measure the same.
Also were washers used with these bolts?
Thanks
Graham Freeman is offline   Reply With Quote
Old 02-08-2018, 07:38 AM   #6
Terry,OH
Terry,OH's Avatar
I believe these Dim to be correct:
3/4" Hex X 0.200" thick, sharp corners, slight chamfer on the head
0.500" Dia. X 0.185" long shoulder
OAL= 1.00"
3/8-24 thread with an undercut so the nut screw all the way to the shoulder.
They may be reproduced and being sold here on Fordbarn.com check the for sale ads.
Old 02-08-2018, 07:42 AM   #7
Terry,OH
Terry,OH's Avatar
Nut 3/4 X 3/4 X 0.325 T all sharp corners
Old 02-08-2018, 08:11 AM   #8
d210000439
Thanks, that’s a big help
Old 02-08-2018, 08:55 AM   #9
motordr
I have four NOS bolts that look similar. 15/16” hex head, 3/8” NC , 1 1/2” over all length. .621” shoulder diameter, .300” wide shoulder. Any idea what they are for?
motordr is offline   Reply With Quote
Old 02-08-2018, 10:41 AM   #10
d210000439
My top frame is all rivets. It’s bolted at the door pillars and behind the seat
Old 02-10-2018, 05:20 PM   #11
d210000439
I stand corrected, there are top bolts in the 1933 Cabriolet convertible top.
I'll post a picture (f I can figure that out) and there is a washer between the bow and the frame.
Shoulder bolt:
Hex head 5/8 x .160 thick
Shoulder 3/8 diameter x .450 long
Thread is 1/4 28 x .290 long
.900 Overall length
Washer is .065 thick 3/4 OD .395 ID
Old 02-10-2018, 05:45 PM   #12
DavidG
DavidG's Avatar
With respect, the top irons were chrome plated originally, not nickel plated.
DavidG is online now   Reply With Quote
Old 02-10-2018, 10:30 PM   #13
Graham Freeman
Thanks for the dimensions.
Some questions still.
Is the washer steel or brass like between the hood irons where the rivets are?
What is the finish on the bolt?
Does this bolt also hold the small bracket that is shown on page7-15 of the 33/34 restoration manual?
Old 02-11-2018, 08:39 AM   #14
d210000439
The bolt head is chrome plated the washer is steel.
We may be talking 2 different parts here. The bolt I'm talking about goes in the top of the convertible frame and attaches the top bow to the convertible frame.
What I see on page 7-15 is hood and cowl details.
Old 02-12-2018, 01:11 AM   #15
Graham Freeman
Sorry my fault a typo error.
The page I meant was 7-45 top rh corner.
Also any chance of a dimension across the width of the steel bow just to check that my one is not out of shape inside to inside (or outside to outside) at the bolt pivot point would be great.
Thanks for the other dimensions I should be able to manufacture a couple of bolts with those measurements.
Old 02-12-2018, 09:41 PM   #16
d210000439
I’ll have a look but can’t get to it before the weekend
Old 02-19-2018, 06:53 AM   #17
d210000439
Mine measures 49 inches inside to inside
Old 02-21-2018, 02:01 AM   #18
Graham Freeman
Thanks for that.
My one measures 48 13/16" so with yours at 49" and another 2 measured at just over that i shall open my one out to 49".
