03-01-2016, 12:07 PM | #1 |
Brake rod anti-rattler springs
How do I get the springs over the eye at the end of the brake rods?
03-01-2016, 12:25 PM | #2 |
Re: Brake rod anti-rattler springs
Has to come from the other end.
03-01-2016, 12:52 PM | #3 |
The way i understand it, is that the springs push the rods away from the cross shaft. I have attached a drawing that I am working from. I will be able to slip the springs on the rear rods from the adjustable eye end, but the front rods, i would need to get the springs over the fixed eye?
03-01-2016, 01:02 PM | #4 |
Yes, the springs push the rods away from the cross shaft. In both cases, they go on from the adjustable eye end. I had to think about it a few minutes - it works.
Doug
Doug in Waterloo |
03-01-2016, 04:00 PM | #5 |
If you turn the front brake rods around and put the clevis on the cross shaft, then the upsets are in the wrong place. How do you move them?
03-02-2016, 05:20 PM | #6 |
03-02-2016, 05:33 PM | #7 |
Just spread the end a little to get it over the eye and then squeeze it back.
Bob |
