Old 06-02-2015, 08:33 PM   #1
henry's 31
Default Cork VS neoprene gasket in gas gauge
Hi fellow Ford Barn members:
I am in the process of replacing the gas gauge in my 31 roadster and I am undecided if I should use cork or neoprene gasket in the opening of the gas tank. Which one will be more ressistant to the ethanol? Also which is the best sealer to use on these different gaskets? Andrew's just mentions a gasoline proof sealer in his book. Any help will be appreciated.
Thanks,
Henry's 31
henry's 31 is offline   Reply With Quote
Old 06-02-2015, 08:38 PM   #2
Mitch//pa
Default Re: Cork VS neoprene gasket in gas gauge
Cork and no sealer
Old 06-02-2015, 09:00 PM   #3
harleytoprock
I also find cork more fuel proof. I have used permatex paste teflon thread sealer as a gasket sealer for fuel items. Gas doesn't seem to effect it. Don't use RTV silicone with fuel.
harleytoprock is offline   Reply With Quote
Old 06-02-2015, 09:23 PM   #4
bobpo1
bobpo1's Avatar
I used cork with a very thin coating permatex seal several years ago and it has held very well.
Now, on the other hand, use the neoprene float as opposed to the cork float in the tank......It won't soak up gas in time.
bobpo1 is offline   Reply With Quote
Old 06-02-2015, 10:09 PM   #5
al's28/33
al's28/33's Avatar
cork gaskets and a brass float similar to that used in the zenith carbs......search old forms and you'll find out all the particulars....
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 06-02-2015, 11:31 PM   #6
quickchange
quickchange's Avatar
Cork gasket on the guage , use a smear of maple syrup or down under golden syrup; Done lots & no leaks, Derek in a wet cold NZ , Pray the salt stays dry. 9 weeks to go
quickchange is offline   Reply With Quote
Old 06-02-2015, 11:35 PM   #7
160B
160B's Avatar
Maple syrup is a poor substitute in any recipe for "Golden Syrup"!!!!
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 06-03-2015, 07:23 AM   #8
barnstuf
Use the cork gasket set which also includes the thin brass ring.
barnstuf is offline   Reply With Quote
Old 06-03-2015, 10:32 AM   #9
SHEC
SHEC's Avatar
Cork float BUT - neoprene gasket set on the gauge. Good combo - old and new.
Be well -
SHEC
SHEC is offline   Reply With Quote
Old 06-03-2015, 11:02 AM   #10
Mitch//pa
Be well -
SHEC
disagree
that combo has not worked for me so ill stick to the cork gauge gaskets and the modern float instead of cork
Old 06-03-2015, 11:30 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
X2 what Mitch said.
The cork on my float still works fine, but for sure use only cork on the glass lens.
Old 06-03-2015, 01:29 PM   #12
Allanw
Allanw's Avatar
^^^ THis.
Our neoprene gaskets swelled up, and stopped the gauge working properly.
Maple syrup - no leaks, and doesn't dissolve in petrol.
Allan
'29 Tudor, Canadian RHD
Whangarei, NZ
"Duct Tape can't fix stupid, but it can MUFFLE the sound"
Allanw is offline   Reply With Quote
Old 06-03-2015, 08:31 PM   #13
henry's 31
Thank you all for your postings. This website is a super tool available to all of us that love to work in our Model A and helps to provide answers that you can't find in any book or article. Thank you again for helping us keep our A's on the road.
In your debt,
Henry's 31
Old 06-04-2015, 07:07 AM   #14
jimalabam
jimalabam's Avatar
Hi Al: As above, use the cork and the brass seal, never used or thought of the "syrup" idea !!!
jimalabam is offline   Reply With Quote
Old 06-04-2015, 09:08 AM   #15
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by Mitch//pa View Post
disagree
Originally Posted by Tom Wesenberg View Post
X2 what Mitch said.
Originally Posted by Allanw View Post
^^^ THis.
Add me to the list of the neoprene swelled up and the gauge stopped working.
Old 06-04-2015, 10:15 PM   #16
henry's 31
Hi Jim:
Glad to hear from you and thanks for the information,
Henry's 31
Old 06-04-2015, 11:20 PM   #17
J Franklin
J Franklin's Avatar
Ethanol swells the neoprene. real gasoline doesn't seem to.
Old 06-05-2015, 10:22 AM   #18
SHEC
SHEC's Avatar
I guess we are lucky out here in CA as we don't have a lot of ethanol fuel. Still would not purchase it if readily easily available! I have been lucky since my American made Neoprene set has been in the car for over 25 years.
Sorry to hear of others having trouble but good to see the original cork set up (as designed) still works fine -
Thanks folks -
SHEC
Old 06-05-2015, 09:40 PM   #19
Allanw
Allanw's Avatar
No ethanol in our fuel, and the neoprene swelled until the guage would jam showing full, unless you pushed the float down with a stick - the same one we had to use to measure the fuel level
I pulled the gauge back out, used a scalpel to trim the swelled part off, and all is OK, but I'd either use the cork, or some decent fuel-proof material to make my own next time.
Allan
Whangarei, NZ
Old 06-05-2015, 11:29 PM   #20
Mike V. Florida
Thanks folks -
SHEC
There are only 19 station in all of california that sells 100% gasoline.
http://pure-gas.org/index.jsp?stateprov=CA
