Old 11-12-2019, 09:06 AM   #1
jkflathead
Default 35 Ford Columbia Speedometer?
I am about to install the controls for an original Columbia two speed rear end in my '35 Ford coupe. Would it be ok to not install the speedometer conversion assembly under the dash? I understand that the speedometer will be off by 10-12 mph. Other than that is there a problem? I guess that I would have to block off one of the vacuum ports going to that mechanism. Advice? Thanks.
jkflathead is offline   Reply With Quote
Old 11-12-2019, 10:17 AM   #2
KGS
KGS's Avatar
Default Re: 35 Ford Columbia Speedometer?
No problem. I ran mine for quite a while until I got the changer. Just do the math when in overdrive; increase the indicated speed by 30%. BTW, my changer doesn't use vacuum, it's manually changed.
KGS is offline   Reply With Quote
Old 11-12-2019, 10:48 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
No vacuum ports for the speedometer, it uses linkage for the original system, perhaps you have later control
