Old 08-29-2019, 11:46 PM   #1
Pandersen33
Pandersen33's Avatar
Default Parking brake interchangeable?
Is it possible to just bolt in a later style parking brake in a 29 or do i need the entire later transmission?
Pandersen33 is offline   Reply With Quote
Old 08-29-2019, 11:54 PM   #2
Pmsqrd
Pmsqrd's Avatar
Default Re: Parking brake interchangeable?
All 3 speed Model A transmission cases will accept all towers. However the parts down stream from the handle can be different.
Pmsqrd is offline   Reply With Quote
Old 08-30-2019, 03:34 PM   #3
1955cj5
1955cj5's Avatar
You will need a different tower, as mentioned.
These two pictures show the side mount brake lever and the front mount. Same transmission, different towers...both on a '29.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
