Old 08-12-2019, 08:15 AM   #1
Dan 1939
Dan 1939's Avatar
Default Axles 1939 Pickup ??
The axles in my 1939 pick up show some wear in the area of the grease seals (see picture). I'm not sure that a new seal will help or if I should I replace the axles. What are your thoughts.
Also, where can I buy new axles or can mine be repaired?
Does anyone have a set in very good condition for sale.
Dan 1939 is offline   Reply With Quote
Old 08-12-2019, 08:26 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: Axles 1939 Pickup ??
I would be inclined to replace them. If you were closer I have a complete '39 rear axle assembly I'd sell you very reasonably.
Seth Swoboda is offline   Reply With Quote
Old 08-12-2019, 10:19 AM   #3
marko39
What is their length and number of gears?
marko39 is offline   Reply With Quote
Old 08-12-2019, 02:33 PM   #4
alanwoodieman
what about a repair sleeve, like they do with a harmonic balancer?
alanwoodieman is offline   Reply With Quote
Old 08-12-2019, 02:35 PM   #5
19Fordy
19Fordy's Avatar
Is it possible to have them metal sprayed and surface hardened?
Old 08-13-2019, 02:47 PM   #6
Dan 1939
Dan 1939's Avatar
The axles have 18 tooth gears and are approximately 32 1/2 inches each.
Old 08-13-2019, 09:14 PM   #7
tubman
tubman's Avatar
Here's a suggestion that's completely of the wall. How about making some spacers to go under the seals to space them out another 1/16th of an inch? That way, they'll run on a virgin surface.
Old 08-14-2019, 08:35 AM   #8
Dan 1939
Dan 1939's Avatar
I took the axles to a local machine shop yesterday. They told me essentially the same thing, space out the seal to area on axle without wear.
Thank you all for responses and suggestions.
Dan
Old 08-14-2019, 10:40 AM   #9
Seth Swoboda
Sounds like you have it covered.
Old 08-14-2019, 06:03 PM   #10
russcc
That's a great idea. Turn out some spacers on the lathe and reposition the seals.
russcc is offline   Reply With Quote
Old 08-15-2019, 05:12 PM   #11
42merc
42merc's Avatar
Dick Spadaro's fix - stack a new seal on top of the old one, provides a fresh wear area.
42merc is offline   Reply With Quote
Thread Tools
Display Modes
