02-14-2019, 07:25 PM | #1 |
Lower rad hoses
I put the motor back in my '35 1-1/2ton but don't know what I need for lower rad hoses. When I pulled the motor (and rad) there was just straight hoses from the pumps to the rad BUT, someone had stacked two sets of motor mounts to raise the motor so the inlets/outlets would line up. They then had to cut a notch in the frame so the pass side exhaust could clear because the engine was too high. I fixed the frame and put new motor mounts but now the top of the water pump inlets are in line with the bottom of the rad outlets so it appears I need a "Z" shaped hose or perhaps there was a "Z" shaped pipe that attached with two short hose sections. Then again, it COULD be the wrong rad perhaps.Truck is a '35, engine is a '47 if that matters.
02-14-2019, 08:02 PM | #2 |
Re: Lower rad hoses
These will work for a close hookup. https://www.honestcharley.com/offset...onnectors.html
Many years ago I bought offset hoses like in this kit. Can't remember where I got them alone. https://www.macsautoparts.com/ford_m...stock-fan.html |
02-14-2019, 08:07 PM | #3 |
Re: Lower rad hoses
I used gates 20151. amazon has them.
02-14-2019, 08:18 PM | #4 |
Re: Lower rad hoses
lower hoses for an 8ba have the double curve to help get around the crossmember. not sure on yours, but that is the trick for 34's
02-15-2019, 05:19 AM | #5 |
Re: Lower rad hoses
Cas3 has the answer, I use 8BA lower hoses when fitting 59A series engines into my 35.
02-15-2019, 07:28 AM | #6 |
Re: Lower rad hoses
02-15-2019, 09:29 AM | #7 |
Re: Lower rad hoses
Only the top hoses.
02-15-2019, 03:49 PM | #8 |
Re: Lower rad hoses
02-16-2019, 02:43 PM | #9 |
Re: Lower rad hoses
Think it is just to match up with the smaller radiator inlets.
02-17-2019, 05:07 AM | #10 |
Re: Lower rad hoses
Think the general idee is that a pump wants bigger hoses on the suction side then on the pressure side...
02-17-2019, 06:58 PM | #11 |
Re: Lower rad hoses
There’s a guy on the HAMB selling bottom Z hose
"I can't cry as long as I know the Lord has risen " |
02-23-2019, 03:33 AM | #12 |
Re: Lower rad hoses
Thanks for all the replies. Been looking but haven't found a source for lower hoses listed for the 8BA. The lower "S" hoses that my supplier shows have way too much sweep to them. I did find some on the HAMB offered by a guy in Finland that look correct but with shipping and exchange are PRICEY!!!!
02-23-2019, 08:26 AM | #13 |
Re: Lower rad hoses
Can you make some out of copper tubing and elbows soldered together with short piece of straight hose at each end similar to this? 8BA in a 40 Ford with 8RT water pumps.
02-23-2019, 10:05 AM | #14 |
Re: Lower rad hoses
When I need a special hose I use pieces of old hose and steel tubing (you can also use plastic pipe) and make myself something that fits what I need. I then take that made up pattern to my local Napa store and roam through their hoses. Sometimes you may have to buy a hose that is too long, but has the correct bends to match your pattern. Works every time for me. Save the hose part # for future reference and replacement.
02-23-2019, 12:01 PM | #15 |
Re: Lower rad hoses
the gates # for the hose is 20151, i just ordered some yesterday, counter man had no trouble finding them. any of the vendors should have them also. i too saw the ad from finland and wondered why any one would be trying to sell used hoses?
02-23-2019, 02:08 PM | #16 |
Re: Lower rad hoses
If its Aulitz from Finland he has them made up and they are new ,not used.Here is a link on the HAMB to his ad.
https://www.jalopyjournal.com/forum/posts/12324063/ |
02-23-2019, 11:57 PM | #17 |
Re: Lower rad hoses
interesting that the guy had his own hose design made. i have a neighbor of 40 years from finland, and have even gone home with him to visit the family. i'll tell you, they are a "get r done" bunch of folks over there. the only country that repaid its ww2 debt
02-24-2019, 10:15 AM | #18 |
Re: Lower rad hoses
I already tried that mine don't need to be anywhere near that much deviation from straight. I cut and modified two copper elbows and tis welded them together but the the required curve was still too tight.
02-24-2019, 10:17 AM | #19 |
Re: Lower rad hoses
I've looked at the 20151 and it does not appear to have enough curve. On mine, the bottom of the rad nipple is parallel with the top of the pimp nipple but they are only a couple inches apart. The hoses offer from finland look just right but would be close to $200 CAD by the time they get here
02-24-2019, 10:19 AM | #20 | |
Re: Lower rad hoses
Thread Tools | |
Display Modes | |
